JohnnyGui
- Messages
- 802
- Reaction score
- 51
Given is a function ##P(E)## and its derivative ##f(E)##. Writing ##E## in terms of ##v## according to ##E=\frac{1}{2}mv^2## gives the derivative ##g(v)=f(E)mv## and ##dE=mvdv##.
My issue arises from the premise that I learned; Integrals and derivatives are based on steps of a fixed constant interval. To make my issue clear, let's add a subscript "C" if an interval is considered constant.
When multiplying ##f(E)## by a fixed ##dE_C## I understand that
$$f(E)dE_C=P(v+\frac{dE_C}{mv})-P(v)$$
Furthermore, based on my premise, the derivative ##g(v)## is based on a fixed interval ##dv_C##.
$$g(v)=\frac{P(v+dv_C)-P(v)}{dv_C}$$
Because the interval ##\frac{dE_C}{mv}## varies with ##v##, this means ##\frac{dE_C}{mv}\neq dv_C## since ##dv_C## is considered constant.
My issue is about the following equation that I learned
$$\frac{P(v+dv_C)-P(v)}{dv_C}=\frac{P(v+\frac{dE_C}{mv})-P(v)}{\frac{dE_C}{mv}}$$
I can only accept this equation in the following cases
1. ##P(v)## is proportional to ##v##
2. The equation should be rewritten such that the interval ##\frac{dE}{mv}## is adjusted to equal ##dv_C## or vice versa. For this, ##dE## is actually not a constant but varies with ##v## so that ##\frac{dE}{mv}=dv_C## holds for every ##v##.
I learned case 1. is not necessary to make this equation valid. So is it actually case 2. or is my premise wrong in the first place?
