Confusion in General Relativity
51 replies · 5K views
klen
According to equivalence principle, gravity can be treated like acceleration "locally". Based on this principle we can treat a non-inertial frame at rest and explain the fictitious forces (of Newton's Laws) as gravity. From this we can prove that time elapses at different rates at different positions in gravity and that the space is curved.
But Einstein also said that the curved space-time can be treated "locally" as Minkowski space which is flat.
Doesn't these two ideas contradict each other? From the former reason we are saying that space is curved locally because of gravity and latter is saying that it is flat.
Could anyone please explain this reasoning.
Yes.
No. To show that spacetime (not space) is curved, we need to look beyond a single local inertial frame, i.e., beyond the scope of the equivalence principle. The EP alone does not show that spacetime is curved; curvature is a non-local effect, and as you say, the EP is local.
The equivalence principle says that gravitational effects behave locally like acceleration in flat spacetime. The curvature becomes apparent only when you take a non-local view.
An observer inside a sufficiently small closed room will not be able to tell whether the room is resting in the curved spacetime at the surface of the Earth or being accelerated through flat spacetime at 1g - the spacetime curvature within the room is too small to detect. That's the part about treating curved space-time as locally flat and treating gravity as equivalent to acceleration in flat spacetime.
However, if we make the room large enough, non-local effects that can only be attributed to curvature will start to appear - for example, two objects dropped at the same time will follow very slightly non-parallel paths as their trajectories converge to intersect at the center of the earth.
Hi. Let me tell you some cases.
1. Suppose you are in the accerelating rocket in the space. You feel gravity. You interprete there is constant gravitational field in the whole universe and it is true in your frame of reference.
Suppose you are on the earth. You feel same gravity as you are in the rocket. Your previous interpretaitin on gravity becomes wrong because the gravity has center at the center of the Earth.
"Locally" the gravitational effect on the Earth is same as that of the accerelating rocket.
2. Suppose your brother floats in space and the accerelatin rokcekt passes him.
You and your brother share the same space time point. You feel gravity but your brother feel no gravity. His spacetime is Minkowsky.
Suppose you are on the Earth and your brother is free falling nearby. You and your brother share the same spacetime point again. You feel gravity but your brother does not. His "Local" spacetime is Minkowsky.
Hi, I agree if my brother is falling then his local spacetime is Minkowski but when I am standing on Earth will my local spacetime be Minkowski? Because, by above the argument by Einstein, my spacetime appears to be curved.
klen said:
Hi, I agree if my brother is falling then his local spacetime is Minkowski .
His spacetime is "Locally" Minkowsky because gravity disappears only where he is.
No. your spacetime is curved thus you get gravity. If you want to straighten the spacetime around you jump off following your brother.
Either spacetime is curved at a given point or it isn't; it can't be curved for one person and not curved for another. A person standing on the surface of the Earth is accelerating at 1g (we measure this by asking him to hold an accelerometer, or to stand on a spring scale so that we can directly observe the force that is accelerating him) through a locally flat spacetime. The nearby falling person is moving inertially (no force acting on him as long as he remains in free fall) through the same locally flat spacetime.
Of course this local region of spacetime is not exactly flat - it is very slightly curved, and with sufficiently sensitive instruments both observers would be able to measure this very slight curvature. Their measurements would agree, as the curvature is what it is no matter how the person doing the measurement is moving.
This is incorrect. It's the same slightly curved locally flat spacetime for both.
Yes. The free faller should be infinitesimal small dwarf to escape from your criticism.
klen said:
According to equivalence principle, gravity can be treated like acceleration "locally". Based on this principle we can treat a non-inertial frame at rest and explain the fictitious forces (of Newton's Laws) as gravity. From this we can prove that time elapses at different rates at different positions in gravity and that the space is curved...From the former reason we are saying that space is curved locally because of gravity
Gravitational acceleration and different clock rates doesn't imply space time curvature. See the intrinsically flat cone the first figure here:
http://www.physics.ucla.edu/demoweb..._and_general_relativity/curved_spacetime.html
Also this great post:
DrGreg said:
This is my own non-animated way of looking at it:
  • Two inertial particles, at rest relative to each other, in flat spacetime (i.e. no gravity), shown with inertial coordinates. Drawn as a red distance-time graph on a flat piece of paper with blue gridlines.
  • B1. The same particles in the same flat spacetime, but shown with non-inertial coordinates. Drawn as the same distance-time graph on an identical flat piece of paper except it has different gridlines.
    B2. Take the flat piece of paper depicted in B1, cut out the grid with some scissors, and wrap it round a cone. Nothing within the intrinsic geometry of the paper has changed by doing this, so B2 shows exactly the same thing as B1, just presented in a different way, showing how the red lines could be perceived as looking "curved" against a "straight" grid.
  • Two free-falling particles, initially at rest relative to each other, in curved spacetime (i.e. with gravity), shown with non-inertial coordinates. This cannot be drawn to scale on a flat piece of paper; you have to draw it on a curved surface instead. Note how C looks rather similar to B2. This is the equivalence principle in action: if you zoomed in very close to B2 and C, you wouldn't notice any difference between them.
Note the diagrams above aren't entirely accurate because they are drawn with a locally-Euclidean geometry, when really they ought to be drawn with a locally-Lorentzian geometry. I've drawn it this way as an analogy to help visualise the concepts.
Riemannian curvature is mathematically a local property. So what is non-local about it according to you? If possible give some reference.
The EP must limit arbitrarily to first derivatives of the metric, but how dos this make curvature something non-local?
The EP must limit arbitrarily to first derivatives of the metric, but how does this make curvature something non-local?
When we say that spacetime is locally flat and that curvature is non-local, we're saying that the approximation "it is flat across this region" can be made arbitrarily good by choosing the region in question to be sufficiently small. No matter how small a curvature effect you can detect, there is a region small enough that you can't detect it inside that region.
Conversely, to observe any curvature effect we must consider the trajectories of two test particles that are not colocated, and then we can interpret "non-local" to mean "at least as separated as our two non-colocated particles".
I think you may still be missing the point. Yes, you are right that if we were to shrink both observers down to infinitesimal dwarfs, the "it's locally flat" approximation would become exact in the infinitesimally small locality around each observer. But I was objecting to the suggestion that "If you want to straighten the spacetime around you jump off following your brother", because that's just plain wrong. The spacetime is what it is whether you're accelerating through it or in free fall through it.
That is explained in detail in chapters 3 and 4 here
http://www.preposterousuniverse.com/grnotes/
Thanks. Will restating "If you want to change your frame of reference so that it is locally flat where you (an infinitesimal dwarf) are, " satisfy you ?
@loislane
As an analogy: The Riemannian curvature of a spherical planet surface is the same at each point. But the effect it has on the accuracy of a flat map depends on the size of the mapped area. Over small areas (locally) the distortion due to curvature is negligible.
You are restating that the EP arbitrarily restricts itself to the first derivatives of the metric(non-tensorial coordinate-dependent Christoffel coefficients) for that approximation. It might be clarifying to know the reason why a physical principle is restricted to a coordinate approximation when physicists are so concerned about considering physical only what is coordinate-independent(invariants).
I guess you are referring here to geodesic deviation that uses the Riemannian tensor in its formulation and therefore a local notion o curvature. Riemannian curvature is preserved by local isometries.
The curvature tensor is covariant, so scalars derived from it that measure "the amount of spacetime curvature" (the Ricci scalar is the simplest one) are coordinate-independent. The EP can just as easily be stated as applying only over length and time scales that are small compared to the radius of curvature derived from such scalars. That is a coordinate-independent statement.
Sure.
But here you are introducing the second derivatives of the metric(derivatives of the Christoffels) since you are introducing curvature . These are explicitly left out in the EP, that is only concerned with the first derivatives of the metric, that vnish at the point by using Riemann normal coordinates(and you need this local vanishing or you don't have any equivalence principle). So you can't use a local measure of curvature here to state a principle about equivalence to local flatness by arguing that curvature is coordinate-independent. Curvature can never be equivalent to flatness, that's precisely the reason the EP must be stated in terms of only first derivtives and Riemann normal coordinates.
page 108 of chapter 4 indeed explains what I'm saying about the EP starting by:"
In fact, let us be honest about the principle of equivalence: it serves as a useful guideline,
but it does not deserve to be treated as a fundamental principle of nature. From the modern
point of view, we do not expect the EEP to be rigorously true".
But it doesn't give any alternative other than wait and see if the principle is empiracally ruled out in practice(explaining why this would be quite hard in fact).
If what you are saying is consistent with what Carroll is saying then I don't think that there is any real disagreement here.
I am not sure why you think some alternative is needed. We have a theory which makes testable predictions. The theory reflects the principle meaning that it follows the "useful guideline". So what more is needed?
Sure you can. I gave you an explicit criterion for deciding what "local" means: it means "over length and time scales that are small compared to the radius of curvature of spacetime". That's all the EP requires.
I agree with Carroll on this point; but note that in that case, since the EP is not supposed to be a fundamental principle of nature, the sort of practical criterion I gave above is perfectly adequate.
The disagrement here was about teaching a "useful guideline" as if was a fundamental principle which I think it was what PeterDonis and Nugatory and others are doing, that in the text you recomnended is clearly said it doesn't deserve to be treated as, because it is not even strictly true, in Carroll's words.
Now GR as theory is formulated in terms in which the EP(mathematically minimal coupling) must be exactly true, not just a guide. So it is no wonder that researchers working on quantum gravity consider GR to be just a useful approximation but ultimately wrong. I guess you should be asking them why some alternative is needed and what more is needed. I am just a perplexed mathematician and don't care for alternatives. It does bother me to read certain things.
If you're teaching GR, you teach GR. In GR, the minimal coupling principle is exactly true, so that's what we teach.
If we're talking about whether or not GR is an exactly correct theory of everything, that's a different question. Of course it isn't. But we don't have a more fundamental theory that covers the same domain, so we don't have anything else to teach.
None of our physical theories are "strictly true". They all break down at some point at the edges of their domains of validity. If you're looking for a physical theory that is strictly true in all respects, you're going to be looking a long, long time. In the meantime, physicists use (and teach) actual theories that exist now and give answers that are correct to within our accuracy of measurement, within their domains of validity.
And again that "criterion" for what "local" means in mathematics is just a physical heuristic "guideline"(if not just something you just thought up now basically). That is not what local means in differential geometry. Your criterions(since you introduced a second one) as I explained are simply either "let's arbitrarily forget about derivatives higher that the first ones, even if anything concerning coordinate independence in general requires at least the second derivatives", or "let's use something added to the EP which is curvature itself at a point and let's define the EP with that addition included"..
Ok, what does "local" mean in differential geometry?
Obviously properties defined in the neigbourhood of a point. Clearly that is not restricted to the first derivatives of a tensor field at a point.
More broadly, those properties that when are fulfilled in open sets of a manifold are also true globally.
Agreed; if it were, it would be impossible to define tensors involving higher derivatives, such as the Riemann tensor.
So in your view, can the minimal coupling principle be formulated as a "local" principle?
I wouldn't say in "my view". Minimal coupling cannot be formulated as a procedure that respects local properties as defined in Riemannian geometry(since we are concerned about Riemann curvature) because it basically let's you get away ignoring terms that are necessary to take into account in Riemannian differential geometry.
But I have the feeling(I don't know enoug about seudo-riemannian manifolds to be sure) that in the pseudo-Riemannian generalization used in GR the distinction between local and global properties is not so clear as in classical differential geometry.
I'm not sure I understand this. Consider the two alternative field equations for EM that Carroll gives (equations 4.24 and 4.32):
\nabla_{\mu} F^{\mu \nu} = 4 \pi J^{\nu}
vs.
\nabla_{\mu} \left[ \left( 1 + \alpha R \right) F^{\mu \nu} \right] = 4 \pi J^{\nu}
Both of these are perfectly valid equations from the point of view of differential geometry. The ##\alpha R## term is certainly allowed by differential geometry, but I don't see why it is made necessary by differential geometry. Adopting the minimal coupling principle in order to make ##\alpha = 0## in standard GR is not "ignoring" anything about differential geometry; it's making a physical judgment about what terms to include in a physical theory.
Note, also, that if we're really going to insist on including all possible terms involving curvature, there's no reason to stop at the ##\alpha## term; we could have higher order terms as well, so we would have something like:
\nabla_{\mu} \left[ \left( 1 + \alpha R + \beta R^2 + \gamma R_{\mu \nu \rho \sigma} R^{\mu \nu \rho \sigma} + ... \right) F^{\mu \nu} \right] = 4 \pi J^{\nu}
I don't see why the above wouldn't be just as much "necessary" as the version with only ##\alpha## in it, by the logic you are using.
vs.
I was talking about something a bit less general than differential geometry, indeed it can be said that both are valid in differential geometry without more qualifications.
The distinction I was referring to was between Riemannian and pseudo-riemannian geometry.
You can see this explained here: https://www.physicsforums.com/threads/einstein-hilbert-action-origin.838487/ in posts #15 and #17
