Confusion on relative velocity sign
  • Thread starter Thread starter niko_niko
    2d kinematics
3 replies · 1K views
niko_niko
Problem: Two swimmers, Chris and Sarah, start together at the same point on the bank of a wide stream that flows with a speed v. Both move at the same speed c (where c > v) relative to the water. Chris swims downstream a distance L and then upstream the same distance.
v_PA = v_PB + u_BA
The downstream part is no problem: c_E = c + v.
My only question is why is the upstream velocity of Chris relative to the Earth c-v, as said by the textbook, and not v-c? Assuming v is to the right and positive, doesn't c become negative since it is in the opposite direction?
niko_niko said:
Homework Statement: Problem: Two swimmers, Chris and Sarah, start together at the same point on the bank of a wide stream that flows with a speed v. Both move at the same speed c (where c > v) relative to the water. Chris swims downstream a distance L and then upstream the same distance.
Relevant Equations: v_PA = v_PB + u_BA
In terms of velocity, if downstream is positive, then upstream is negative. If you change the sign of ##c##, then you are changing the positive direction.
PeroK said:
The upstream speed is, of course, ##v -c##, as speed is non-negative.
For some reason, the current speed is ##v## while the swimmer speed is ##c##. With ##c > v##, I make the upstream speed ##c-v##.
Authors would be well advised to pick mnemonic variable names.
If the textbook uses the phrase "upstream velocity", this could be interpreted to indicate the use of an upstream-positive coordinate system. So the positive value ##c-v## would be appropriate.
