Connecting to batteries together in a circuit
  • Context: High School
  • Thread starter Thread starter B4ssHunter
    Batteries Circuit
Connecting two batteries of different voltages in a circuit can lead to significant issues. When a 10V battery is connected to a 5V battery, if connected in parallel with positive terminals meeting, a short circuit occurs, potentially damaging the batteries. Conversely, connecting them positive to negative can create a current flow from the higher voltage battery to the lower voltage one. Additionally, electric power companies transmit electricity at 240 volts, which drops to 220 volts by the time it reaches homes due to voltage transformation aimed at reducing current and minimizing losses in transmission lines.
  • Understanding of basic electrical concepts, including voltage and current.
  • Knowledge of battery types and their characteristics.
  • Familiarity with circuit design principles.
  • Awareness of electrical transmission systems and voltage transformation.
  • Research the implications of connecting batteries in parallel versus series.
  • Learn about battery chemistry and safety precautions for handling batteries.
  • Study electrical transmission systems and the reasons for voltage drops.
  • Explore circuit diagram drawing tools and techniques for visualizing electrical connections.
Electrical engineers, hobbyists working with batteries, and anyone interested in understanding electrical circuits and power transmission systems.
B4ssHunter
what happens when we connect two batteries together in a circuit
on of them is higher than the other
say one of them is 10 and the other is 5
if they are connected such that positives meet , as far as i know a current will flow out of the negative * even though it should flow out of the positive ( conventional current direction )* of the weaker battery with voltage = 5 volt
what if they were connected postivie to negative ?
also , why is the voltage at power sources such as power companies 240 volts while it becomes 220 volts when it reaches homes ? * at my country that's the case *
Can you draw a sketch of the circuits?
Connecting different batteries is not a good idea. If you connect them in parallel (independent of the polarities), you get a short circuit, with bad consequences for the batteries (or even the environment, some batteries can explode).
Electric power gets transformed to higher voltages for transmission, this reduces current and therefore losses in the cables. Close to the consumers, it is transformed back to lower voltages - the value there is independent of the value somewhere at power plants.
  • · Replies 22 ·
  • · Replies 19 ·
