Connection between potential difference and velocity?
The discussion centers on the relationship between potential difference and the velocity of an electric charge. An electric charge accelerated through a potential difference of 250 V reaches a speed of 9.4 x 106 m/s. By applying the conservation of energy principle, participants conclude that if mass and charge are constant, the problem can be solved using ratios. Specifically, the ratio of potential differences and the squares of their corresponding velocities can be established to find the new speed when the potential difference is reduced to 125 V.
  • Understanding of electric potential and kinetic energy
  • Familiarity with the conservation of energy principle
  • Basic knowledge of algebraic manipulation and ratios
  • Concept of electric charge and potential difference
  • Study the conservation of energy in electric fields
  • Learn about the relationship between electric potential and kinetic energy
  • Explore the concept of electric charge and its properties
  • Investigate the mathematical treatment of ratios in physics problems
Students of physics, educators teaching electric fields, and anyone interested in the principles of energy conservation and electric charge dynamics.
mirandab17
Hey there!
Having some difficulty with this question... is there any proportionality law between potential difference and velocity?
An electric charge accelerated from rest through a potential difference of 250 V reaches a speed of 9.4 x 10^6 m/s. What speed will this same charge reach if it is accelerated by a potential difference of 125 V?
So I started with conservation of energy. Ek = Ep.
(.5)mv^2 = Ue = qV
But how can I complete this without knowing its mass or quantity of charge?
Thanks in advance!
mirandab17 said:
Hey there!
(.5)mv^2 = Ue = qV
Thanks in advance!
Just assume that the mass and charge are constant. If you set up the problem in the form of a ratio these constants will cancel out.
If I set it up as a ratio:
2V/v^2 = 2V/v^2
So would I set it up as 2(250)/(9.4x10^6)^2 = 2(125)/v^2
2V/v^2 = 2V/v^2
You should differentiate the V's and v's, perhaps by giving them subscripts to denote 'old' value and 'new' value. Note that you can also cancel the 2's which appear on each side of your equation -- just another constant that vanishes when you use ratios!
But yes, your setup will work.
  • · Replies 30 ·
