Conservation of Energy child's toy
The discussion focuses on calculating the speed of a ball launched from a child's toy, which consists of a spring, a ramp, and a suction cup block. The key equation derived is based on the conservation of energy principle, expressed as Ki + Ui = Kf + Uf. The final speed of the ball upon hitting the floor is determined using the formula vf = sqrt[(ks^2 - 2mgy)/m + 2gh], where k is the spring constant, s is the compression distance, m is the mass, g is the acceleration due to gravity, y is the height of the ramp, and H is the height of the table.
  • Understanding of conservation of energy principles in physics
  • Familiarity with spring mechanics and the spring constant (k)
  • Knowledge of kinematic equations and gravitational potential energy
  • Ability to manipulate algebraic expressions and solve equations
  • Explore advanced concepts in energy conservation in mechanical systems
  • Study the effects of friction and air resistance on projectile motion
  • Learn about the dynamics of springs and oscillatory motion
  • Investigate real-world applications of energy conservation in engineering
This discussion is beneficial for physics students, educators, and anyone interested in understanding the principles of energy conservation and mechanics in practical applications, particularly in educational toy design.
chrispat
A child's toy consists of a block that attaches to a table with a suction cup, a spring connected to that block, a ball, and a launching ramp. The spring has a spring constant k, the ball has a mass m, and the ramp rises a height y above the table, the surface of which is a height H above the floor.
Initially, the spring rests at its equilibrium length. The spring then is compressed a distance s, where the ball is held at rest. The ball is then released, launching it up the ramp. When the ball leaves the launching ramp its velocity vector makes an angle theta with respect to the horizontal.
Throughout this problem, ignore friction and air resistance.
With what speed will the ball hit the floor?
Express the speed in terms of k, s, m, g, y, and/or H.
Ki+Ui=Kf+Uf
0.5ks^2+0.5m(vi^)2+mg(hi)=0.5m(vf)^2+mg(hf)
vf=sqrt[(0.5ks^2)+(0.5m(vi)^2)+0.5m]
where vi=sqrt[(ks^2-2mgy)/m]
chrispat,
The equations in your attempt are all correct statements in that you have appropriate expressions for the quantities vi, Ui - spring, UI - grav, etc. However, when are you declaring your initial values? That is, when during the experiment are you setting time = 0? That decision is entirely up to you, with no wrong answer. However, there are some points in the experiment where it makes better sense to set t = 0, because it allows you to set one of the terms in Ui + Ki = Uf + Kf equal to zero.
There's no reason to have non-zero terms for both Ui - spring and Ki. If you declare your starting time so that you can zero one of these terms out, it will make the problem easier.
Ok so I took t=0 to be when the ball is at its highest point.
0.5m(vi)^2+mg(hi)=1/2m(vf)^2
(vi)^2+2gh=vf^2
Substituting for vi:
[ks^2-2mgy/m]^2+2gh=vf^2
  • · Replies 32 ·
