Conservation of Energy Help (p2)
The problem involves determining the height from which a compact car must be dropped to achieve the same kinetic energy as when it is traveling at a speed of 105 km/h, assuming negligible air resistance. The context is rooted in the principles of conservation of energy.
  • Exploratory, Assumption checking
  • The original poster attempts to apply the conservation of energy equation, equating gravitational potential energy to kinetic energy. There is a discussion about the conversion of units from kilometers per hour to meters per second, with some participants questioning the accuracy of the conversion and the reasonableness of the resulting speed.
The discussion is ongoing, with participants providing feedback on unit conversions and the implications of the speed used in the calculations. There is no explicit consensus yet, as participants are exploring the correctness of the original poster's approach and calculations.
There is a noted concern regarding the conversion of speed from kilometers per hour to meters per second, as well as the implications of using non-SI units in the calculations.
kissafilipino
From what height would a compact car have to be dropped to have the same kinetic energy that it has when being driven at 105 km/h? Unless otherwise directed, assume that air resistance is negligible.
Answer: __ m
Velocity: 105 km/h -> 105000 m/s
Height: ?
Conservation of energy equation: (thanks to user MillerGenuine)
U= potential energy
K= kinetic energy
Conservation of
energy => Kf + Uf = Ki + Ui
K = 1/2mv^2
U = mg(delta h)
My attempt was somewhat he same trying to input in the equation, what height = the same kinetic energy of 115 k/m. So I said, gravitational potential energy = kinetic energy
U = K
mg(delta h) = (1/2)mv^2
Since mass is in both sides, it can be taken out.
g(delta h) = (1/2)v^2
(9.81)(delta h) = (1/2)105000^2
(9.81)(delta h) = (1/2)11025000000
(9.81)(delta h) = 5512500000
delta h = 561926605 m?
Keep your units straight. Kilometers/hour is not SI units.
Exactly, that I understood, which is why I changed it from Km to meters
105 km/h -> 105000 m/s and used it in the equation: mg(delta h) = (1/2)mv^2
You changed km -> m but didn't correctly change hours -> seconds. 105km/h is about the speed a car is driven. Does your speed sound reasonable?
  • · Replies 20 ·
