Conservation of Energy Question
The problem involves the conservation of energy in a system with two masses, where one mass drops a certain distance in the absence of friction. Participants are discussing the application of energy conservation principles to determine the velocities of the masses after the drop.
  • Participants are attempting to apply the conservation of energy principle, questioning the correct formulation of the energy equations. There are discussions about combining the energies of both masses and the initial and final states of potential and kinetic energy.
Some participants have provided guidance on the correct form of the energy conservation equation and emphasized the importance of considering both masses in the energy calculations. There is ongoing exploration of how potential energy converts to kinetic energy during the motion.
Participants are navigating assumptions about initial and final energy states, particularly regarding the potential energy of the masses and the conditions of the system.
SoulEater
In the absence of friction, how fast will the masses move after the 2kg mass has dropped 25 cm? [answer: v = 1.57 m/s]
KE2F + KE1F = PE2I + PE1I
.5*m2*vf2^2 + .5*m1*vf1^2 = m2*g*h2 + m1*g*h1
.5 *2*vf2^2 + .5*1*vf1^2 = 2*9.8*.25 + 1*9.8*?
vf2 = vf1
3/2*vf^2 = ?
Hi Souleater, welcome to PF. Conservation of energy is the right approach, but
is not correct. The correct form is
KEI+PEI=KEF+PEF.
But shouldn't I combine the total energy from both masses?
Yes, and you should also combine the total potential energy for both masses.
Mechanical energy conservation says that
Kinetic plus potential energy of the system at point A is the same as kinetic plus potential energy at point B.
When a mass moves from point A to point B it trades one form of energy for the other form in such a way as to keep the sum the same at all times.
It's like taking money out of your left pocket and putting it in your right pocket. As you do this, you have varying amounts of money in each pocket, but the sum on your person does not change.
But initially, isn't it all potential energy? Therefore the initial kinetic energy for both masses would be 0.
And at the end of the movement, wouldn't both of the masses have converted that potential energy to kinetic energy? Therefore the potential energy at the end would be 0.
The 1kg block will be gaining gravitational potential energy as it rises.
Welcome to PF!
Hi SoulEater! Welcome to PF! :wink:
:smile: KE + PE = constant. :smile:
Thank you. :smile:
So how would the equation look like?
ke1f + ke2f + pe1f + pe2f = ke1i + ke2i + pe1i + pe2i
11K
18K
  • · Replies 21 ·
