How can the tension in the cord be calculated using conservation of energy?
The discussion focuses on calculating the tension in a cord using the conservation of energy principle in a system involving a spool and a falling block. The spool has a mass of 50 kg and a radius of gyration of 0.28 m, while the block weighs 20 kg. The block must fall a distance of approximately 0.3007 m for the spool to achieve an angular velocity of 5 rad/s. The tension in the cord is derived from the relationship between the block's kinetic and potential energy, leading to the equation T + mg ≠ 0 when the block's velocity is increasing.
  • Understanding of conservation of energy principles
  • Familiarity with rotational dynamics and moment of inertia calculations
  • Knowledge of basic kinematics and energy equations
  • Ability to manipulate algebraic equations for solving physics problems
  • Study the relationship between linear and angular velocity in rotational systems
  • Learn about the calculation of tension in cords under dynamic conditions
  • Explore the concept of potential and kinetic energy transformations in mechanical systems
  • Investigate the role of moment of inertia in rotational motion analysis
Students studying physics, particularly those focusing on mechanics, engineers working with dynamic systems, and educators teaching conservation of energy concepts.
joemama69
Use conserbvation of Energy
The spool has a mass of 50 kg and a raius of gratino k = .280 m. If the 20 kg block A is released from rest, determine the distance the block must fall inorder for the spool to have an angulr velocity w = 5 rad/s. Also what is the tension in the cord while the block is in motion.
The spool has a radius of .3m, but where the cord is wrapped around it is a radius of .2m
T1 + v1 = T2 + V2
T & V 1 are both 0 because it starts from rest soooooo...
I = mk2 = 50*.282 = 3.92
0 = 1/2*20*v2 + 1/2*3.92*52 + Wy + 1/2*.25*s2
0 = 59 + Wy + .14s2
s = \sqrt{(-Wy - 59)/.14}
y = (.14s + 59)/W How do i find W
ah W = mass*gravity
W = 50(9.81) = 490.5
so how do i get the y and the s
can anyone give me a hint
I'm not following everything you did, so here are some questions for you:
Which object is W the weight of?
What does "Wy" represent in the energy equation?
What does "1/2*.25*s2" represent in the energy equation?
0 = .5mv2 + .5Iw2 + Wy + .5ks2
I = mk2 = 50(.282) = 3.92
0 = .5(20)v2 + .5(3.92)w2 + 20(9.81)y + .5(.28)s2
oops, my W was wrong, should be 20(9.81)
Wy represents the Potential Energy of Gravity, i would have to solve for y to find the distance the block falls
.5*.25*s2 represents the elastic potential energy, i would have to solve for s to find the stretch of the rope
0 = 10v2 + 1.96w2 + 196.2y + .14s2
is this wrong, how do i finish from here
Where did you get the 0.25 from in that equation? It wasn't given in the problem statement.
Hint: forget about rope stretch in this problem. Assume the rope does not stretch.
However, you will have to figure out how v and ω are related.
the .25 should be the .280 = k, sorry i should have been more carfull
I = 3.92, v = wr = 1, w = 5
0 = 1/2(20)(12) + 1/2(3.92)(52) + 20(9.81)y
y = 59/196.2 = .3007 m,
Now i need to get the stretch of the rope, hint please
The problem asks for the tension in the cord, not the amount of stretch.
Units!
k=0.28 m. It is the radius of gyration of the spool, not the spring constant of the cord.
Spring constants have units of N/m, so this k=0.28m cannot be a spring constant.
Looks good!
On Wikipedia it says Tension (T) is ... T + mg = 0 where velocity is constant, and T + mg \neq 0 where velocity is increasig
T + 20(9.81) = 0 when T = -196.2 is that correct
Since the velocity is increasing, T + mg 0.
Again, think in terms of energy: the work done on the brick, and the change in energy of the brick.
Work done on brick
Wy= 20(9.81)(.300713) = 59
The energ goes from potentil to kinetic,
is there an equation for this, i can't find one
(Work done on brick) = (Change in total energy of brick)
= (Change in kinetic energy of brick) + (Change in potential energy of brick)​
FYI, you can treat "Work done on brick" as entirely due to the tension in the cord. So if you know the change in the brick's kinetic and potential energy, as well as the distance the it moved, you can solve for the cord tension.
  • · Replies 22 ·
