Conservation of linear momentum applied to rotating systems? (with picture)
The discussion centers on the application of conservation of linear momentum in rotating systems, specifically when a bullet strikes a stick at a distance from its center of mass. Participants clarify that the center of mass (CM) of a free stick will indeed move after impact, regardless of whether the bullet strikes at the CM or slightly away from it. Both linear and angular momentum are conserved during the collision, and the linear velocity of the CM is relevant even in a rotating system. The analogy of pushing a ruler illustrates that motion involves both translation and rotation.
  • Understanding of conservation of linear momentum
  • Knowledge of angular momentum principles
  • Familiarity with rigid body motion
  • Basic physics concepts related to center of mass
  • Study the principles of conservation of angular momentum in collisions
  • Explore the dynamics of rigid body motion in physics
  • Learn about the mathematical formulation of center of mass in various systems
  • Investigate real-world applications of linear and angular momentum conservation
Students of physics, educators teaching mechanics, and anyone interested in understanding the dynamics of collisions and motion in rotating systems.
lillybeans
I've encountered problems like this: A bullet with velocity v strikes a stick (intially at rest) at a distance d from the center of mass, then the bullet sticks to it, and the bullet-stick system rotates about the center of mass. But they ask me to find weird things like the speed of center of mass (v in the equation below), which requires me to apply conservation of LINEAR momentum.
Question: Isn't the center of mass MOTIONLESS if the bullet-rod system is rotating? Although it IS possible to calculate the linear velocity of the center of mass after the collision, why is it even relevant in the case of a rotating system?
If the bullet had striked the rod AT the rod's center of mass, then sure, this question makes sense, as the bullet-stick moves forward with that linear velocity, and conservation of linear momentum is relevant. But if the bullet strike anywhere AWAY from the stick's center of mass, the system will rotate and the center of mass will NOT move. So, WHAT DOES THIS NON-ZERO VALUE I GOT FOR THE LINEAR VELOCITY OF CENTER OF MASS REPRESENT IN THE CASE OF A ROTATING SYSTEM?
Thanks in advance,
Lilly
The centre of mass will move after the impact if it is not fixed. As I understood the problem the stick is free. Any in-plane motion of a rigid body consist of a translation and a rotation about the CM. Both the linear momentum and the angular momentum are conserved in the impact.
Put a ruler on the table and give it a push. It will move away, but at the same time it will rotate, too. Do you really think that the CM will move if the bullet strikes the stick exactly at the CM, but will not move at all if the bullet hits it 0.1mm away from the CM?
ehild
ehild
Thank you very much! Very clear explanation!
You are welcome.
ehild
16K
  • · Replies 62 ·
13K
  • · Replies 71 ·
  • · Replies 18 ·
