Conservation of momentum in pulley
In a system with two blocks connected by a string over a pulley, applying a force to one block results in equal and opposite motion of the other block. While it may seem that the total momentum is zero due to their opposing velocities, the external force acting on the pulley and its connection to the Earth must be considered. The applied force adds momentum to the Earth, maintaining the overall momentum of the system at zero. According to Newton's laws, the interaction between the masses and the pulley means that momentum is conserved for the entire system, not just the individual components. Ultimately, the total momentum remains unchanged as the forces balance out.
jd12345
Two blocks of mass m connected by a light string passing over a pulley.
Say, one of the blocks is pushed downwards with a force F and it attains velocity v.So the other block moves upwards with the same speed v right?
Total moementum = mv - mv = 0( because one is moving upwards and other downwards so opposite directions of velocity)
So we applied force but still no momentum change??
Where did i go wrong??
Momentum is a vector, for one thing. Direction counts. And do not ignore the external force of the pulley's axle on the system.
When you push on the one mass, you are also pushing on the pulley, and the pulley is connected to the earth, so you are pushing on the Earth too. Momentum is only conserved for the whole system, not its pieces. The pieces are the two masses, you, and the pulley-earth (they are rigidly connected). The force that you apply adds momentum to the earth, not to the masses.
When you push on the mass, it pushes back (Newton's law). That means you have momentum up, which matches the down momentum of the pulley-earth. Total momentum is still zero. When you stop applying the force, gravity pulls you and the pulley Earth together, and both stop. The masses are moving with zero momentum, you and the pulley Earth are motionless, and again, total momentum is zero.
I built a device designed to brake angular velocity which seems to work based on below, i used a flexible shaft that could bow up and down so i could visually see what was happening for the prototypes. If you spin two wheels in opposite directions each with a magnitude of angular momentum L on a rigid shaft (equal magnitude opposite directions), then rotate the shaft at 90 degrees to the momentum vectors at constant angular velocity omega, then the resulting torques oppose each other...
  • · Replies 30 ·
  • · Replies 53 ·
