Conservation of momentum scenario
The discussion revolves around the conservation of momentum in scenarios involving collisions between a bullet and a stationary object, particularly focusing on inelastic collisions and the implications of external forces on momentum conservation. Participants explore various conditions under which momentum may or may not be conserved.
  • One participant proposes a scenario where a bullet penetrates a stationary block on a frictionless surface, questioning how momentum conservation can be mathematically shown.
  • Another participant argues that if the bullet's velocity changes, it implies a force acted on it, which would also affect the block's velocity, contradicting the initial condition of the block remaining stationary.
  • A new scenario is introduced where the impacted object is stationary and possibly mounted, with a participant suggesting that momentum would not be conserved due to external forces acting on it.
  • Some participants assert that momentum is always conserved in closed, isolated systems, but challenge the notion that the bullet-block system is isolated when external forces are present.
  • One participant emphasizes that the entire system must be considered, including external forces like the Earth, to properly apply the conservation of momentum principle.
  • Another participant reiterates that for momentum conservation to apply, the system must be isolated, and external forces invalidate the conservation in the bullet-block scenario.
Participants express disagreement regarding the conditions under which momentum is conserved. Some maintain that momentum is always conserved in isolated systems, while others argue that external forces in the given scenarios prevent momentum conservation.
Participants highlight the importance of defining the system boundaries and the presence of external forces, which complicate the application of momentum conservation laws. There are unresolved aspects regarding the mathematical treatment of momentum changes in the scenarios discussed.
Sidney
if a nice fuzzy block is stationary on a frictionless surface and is hit by a high velocity bullet in such a way that the bullet cleanly penetrates and exits the box leaving the box stationary but the velocity of the bullet slightly changed, what can one say about the conservation of momentum of the system..? how can it be shown mathematically that the momentum is conserved
This is not possible.
If the velocity of the bullet changed then there was a force on the bullet. If there was a force on the bullet then there was an equal and opposite force on the block. If there was a force on the block then its velocity changed.
ok, new scenario, describe the momentum changes when the impacted object is stationary by all means (maybe it's even mounted) and is impacted by a high velocity object and the collision is completely inelastic
Sidney said:
ok describe the momentum changes when the impacted object is stationary by all means (maybe it's even mounted) and is impacted by a high velocity object and the collision is completely inelastic
I suppose that momentum would not be conserved. There are external forces acting on the impacted object.
what does that mean, momentum is not conserved?? is it not a law that it always is..?
can the problem not be split up in some way as to mathematically describe the changes in momentum like the ballistic pendulum for example..
Momentum is always conserved. In your scenario where the impacted object is mounted firmly to some larger object (the Earth for example), then the momentum of the impacted object plus the Earth changes by an amount equal and opposite to the momentum change of the bullet. But since the mass of the Earth is so large, the momentum change of the block plus the Earth is immeasurably small.
Anyone that told you that momentum is always conserved was doing you a disservice.
The momentum of a closed, isolated system is constant. However, in your example there are external forces acting on the system. Namely, whatever is holding the impacted object in place.
Having read your posts here, the problem you are having is not realizing what the "entire system" is that is involved in the conservation law.
Note that in an ISOLATED SYSTEM, meaning no external forces acting on it, then the momentum of the ENTIRE SYSTEM is conserved.
When you fixed something or attach it to something (like the earth), then the entire system now includes the earth! This is because by fixing it to the earth, whatever you do to that object, the Earth will provide the counter force to it. So the bullet-block system is not an isolated system. Your isolated system is now bullet-block-earth. The conservation of momentum only applies to that system, not to bullet-block.
Zz.
As was mentioned by others, momentum is only conserved for an isolated system, meaning no external force. This system (bullet + block) is not isolated as the mounting provides an external force. Therefore the momentum of this system is not conserved.
If you wish to analyze the system using conservation of momentum then you need to expand the system to include the object providing the force which keeps the block stationary.
