Consider a Hydrogen atom in the ground state
9 replies · 15K views · last reply
jcvince17
Find:
A- The Kinetic Energy, in eV
B - The Potential Energy, in eV
C - The Total Energy, in eV
D - minimum energy required to remove the electron completely from the atom, in eV
E - What wavelength does a photon with the energy calculated in part (D) have
Vn= (1/Eo)(e2/2nh)
Kn = 1/2 mv2 = (1/E02)(me4/8n2h2)
Un = (1/E02)(me4/4n2h2)
mass of H =1.008
I have no idea. I know i need to use the first listed equation to solve for v in order to use the second and find the Kinetic Energy. But how do i do the first equation since i do not know the E0
Please guide me
If those equations are from your textbook, then they should have a definition for E0 if not the actual value.
Also, something looks wrong. U should have a greater magnitude (and opposite sign) than K, but you have it the other way around.
I fixed my equations.
now using the first equation to find K. I used the following values:
E0 = 8.854x10-12
m = 1.66*10-27 (i think that's right for Hydrogen)
e = 1.602x10-19
h = 6.626x10-34
n = 1
Kn = (1/E02)(me4/8n2h2)
plug in the values and i get K = 1.28x1022 x 12.17
K = 1.55x1023
but that is wrong. where am i messing up? I only have one try at the answer left.
what is the correct mass of Hydrogen. I am using 1.66x10^-27. But when i do so and multiply it by e^4 i get 0. which makes everything 0 and this is incorrect.
K and U should be a lot smaller than 1 Joule; the answer should have 10 raised to a negative exponent. It may be that you divided where you should be multiplying, or vice-versa, when you put the numbers into your calculator.
I get 1.67 x 10^-27 kg, but that's a small difference and shouldn't really matter.
You could try separating the number from the exponent part, and do those calculations separately. For example:
(6 x 10^8) x (2 x 10^-19)^2 / (4 x 10^-4)
= [ 6 x 2^2 / 4 ] x 10^[8 - (19x2) + 4]
= 6 x 10^-26
That way, the extremely negative exponents won't turn your answer into 0.
Also, it's good practice to include the units in the calculations. This is one way to check that (1) the formulas are consistent and (2) you are multiplying or dividing the terms correctly.
Good luck!
i tried doing the exponents separately:
for the me^4 part of equation
(1.67 x 10^-27) x (1.602 x 10^-19)^4
= [ 1.67 x 1.602^4 ] x 10^[-27- (19x4]
= 10.99 x 10^-103
that looks very wrong. and when i try to divide/multiply it by something i get an error in the calc's.
now what am i doing wrong?
another member of another forum suggested another equation:
Kn = 1/n2 * 13.588 eV
if i use this the n will be 1 therefore my Kn is 13.588...?
he also pointed out i am using the wrong mass. i am using mass of atom and i should be using the mass of electron.
well i am trying to work out the units only to make sure i have the equation right. but i am not ending with eV
E0 = C^2/N x m
m = kg
e = C
h = J x s (or N x m x s)
n = unitless
i get:
(1/m)(kg x C^2 / s)
i can't convert or cancell anything else out. this problem is driving me insane
Ah, yes, it should be the electron mass. Sorry I didn't catch that sooner.
If you can just use the 13.6 eV value (or 13.588 eV?) in the formula, that is certainly a lot easier.
I don't have time at the moment to check your units calculation, but note the units of εo are C^2 / (N m^2).
i found a new equation in the book.
K = 13.6 ev / n^2
U = -27.2 eV / n^2
E = K + U
i knew E = 13.6.
I finally got them all to work out without having to deal with the error's in the exponents.
now i solved part D and Part E.
thanks
