Constant on [epsilon, 2epsilon] implies f'(0)=K
  • Thread starter Thread starter RBG
    Constant Epsilon
10 replies · 2K views
RBG
Warning: I realize the title is misleading... the function itself isn't what's constant.
Mod note: Edited to fix the LaTeX
If ##f## is a continuous at 0 such that ##\lim_{x \to 0}\frac{f(x)-f(g(x))}{g(x)}=M##, where ##g(x)\to 0## as ##x\to 0## does this generally mean that ##f'(0)=M##? I have been working on the case that ##g(x)=x/2##. It seems like this should be the case since you are saying the secant line on any ##[\epsilon, 2\epsilon]## is constant, so as ##\epsilon## tends to zero, the slope will approach the slope of the tangent line. I've been trying to fudge the definition of continuity to get this and show ##|f'(0)-h(0)|<\epsilon## where ##h(t) = \lim_{x\to t} \frac{f(x)-f(g(t))}{x-g(t)}##
Definition of continuity - \epsilon-delta and limit
Definition of differentiability
Mean Value Theorem
Sequences of functions?
on Phys.org
If $f$ is a continuous at 0 such that $\underset{x\to 0}{\lim}\frac{f(x)-g(x)}{g(x)}=M$ does this generally mean that $f'(0)=M$? I have been working on the case that $g(x)=x/2$. It seems like this should be the case since you are saying the secant line on any $[\epsilon, 2\epsilon]$ is constant, so as \epsilon tends to zero, the slope will approach the slope of the tangent line. I've been trying to fudge the definition of continuity to get this and show $|f'(0)-h(0)|<\epsilon$ where $h(t) = \underset{x\to t}{\lim}\frac{f(x)-f(t)}{x-t}$
Mean Value Theorem
Hello RBG. Welcome to PF !
Code:
Use $$ (Double dollar sign.) to set off LaTeX on an individual line.
Use ## to set off LaTeX  for in-line style.
As follows:
If ##f## is a continuous at 0 such that $$\underset{x\to 0}{\lim}\frac{f(x)-g(x)}{g(x)}=M\,,$$ does this generally mean that ##f'(0)=M##?
Code:
As follows:
Thank you! Also, I edited my question to what I meant. I am really more just interested in the ##g(x)=\frac{x}{k}## where ##k\in\mathbb{N}## case.
If ##f## is a continuous at 0 such that ##\lim_{x \to 0}\frac{f(x)-g(x)}{g(x)}=M##, where ##g(x)\to 0## as ##x\to 0## does this generally mean that ##f'(0)=M##? I have been working on the case that ##g(x)=x/2##. It seems like this should be the case since you are saying the secant line on any ##[\epsilon, 2\epsilon]## is constant, so as ##\epsilon## tends to zero, the slope will approach the slope of the tangent line. I've been trying to fudge the definition of continuity to get this and show ##|f'(0)-h(0)|<\epsilon## where ##h(t) = \lim_{x\to t} \frac{f(x)-f(t)}{x-t}##
Mean Value Theorem
Your condition does not imply ##f'(0) = M##. For example, take ##f(x) = (M+1) g(x) \, \forall \, x##, which certainly satisfies your limit condition. If you take ##g(x) = \sqrt{|x|}## you will see that ##f'(0)## need not even exist.
For the case of interest, namely, ##g(x) = kx## you can compute ##f'(0)## and see what you get.
PeroK said:
$$\underset{x\to 0}{\lim}\frac{f(x)-x/k}{x/k}=M \ \Rightarrow \ \underset{x\to 0}{\lim}\frac{f(x)}{x} = \frac{M+1}{k}$$
Woops! Man, for a first post I am messing up a lot. I meant what my edits say, that is ##f(g(x))## not just ##g(x)## in the numerator!
##f'(0) = \underset{x\to 0}{\lim}\frac{f(x/k)-f(0)}{x/k} \ne \underset{x\to 0}{\lim}\frac{f(x) - f(x/k)}{x/k}##
For example. Try ##f(x) = x##:
##\underset{x\to 0}{\lim}\frac{f(x) - f(x/k)}{x/k} = k - 1 \ne f'(0)## (unless ##k = 2##)
So if we're in the ##k=2## case and the only thing I know about ##f## is that it's continuous at ##0##, how would I show that ##f'(0)=M##?
See Samy_A's post below. ##k = 2## is a special case.
Now I'm confused too.
Lets assume that ##f## is differentiable at ##x=0##, and ##M=\underset{x\to 0}{\lim}\frac{f(x) - f(x/2)}{x/2}##
##\frac{f(x)-f(0)}{x}=\frac{f(x)-f(x/2)+f(x/2)-f(0)}{x}=\frac{f(x)-f(x/2)}{x}+\frac{f(x/2)-f(0)}{x}=\frac{1}{2}\frac{f(x)-f(x/2)}{x/2}+\frac{1}{2}\frac{f(x/2)-f(0)}{x/2}##
Taking the limit for ##x \to 0##, we get ##f'(0)=\frac{1}{2}M+\frac{1}{2}f'(0)##, so ##f'(0)=M##.
But I assumed that ##f## is differentiable at ##x=0##. What he wants to prove is that if ##M=\underset{x\to 0}{\lim}\frac{f(x) - f(x/2)}{x/2}## and ##f## is continuous at ##x=0##, then ##f## is also differentiable in 0.
For now, I find neither a proof, nor a counterexample.
