Constant power, resistance, work, energy
18 replies · 2K views · last reply
Demonfruzz
Mass car 1200 kg .
power car constant 20kw .
Resistance car motion 500N.
Car passes point X and Y with speeds 10 m/s ,25 m/s.
Car takes 30.5 s to travel from X to Y
1. Find acc of car at x
2.considering work/energy find distance XY
T
Demonfruzz said:
Mass car 1200 kg .
tried a few but looks nowhere near promising and I don't have an answer for the question ,past year examinations
It is difficult to provide you any guidance if you do not show us your work. Please post your attempt at a solution, no matter how incorrect you may think it is.
You might start by finding the net driving force at point A ( car driving force = power (watts) / velocity (m/s) )
The acceleration at that point = net force / mass
Hint: A velocity v acceleration graph covering the speed range will be a curve
1. Distance used from question 2.
work = force x distance
Force =610KJ/470 m
=1297.9
acceleration = force/mass
=1297.9/1200
=1.0815
2. Power x time = work
Work= 20kw x 30.5
=610kj
Resistance = 500N x distancexy
Net =kinetic energy
610kj - (500N x distancexy )= (0.5 )
(1200)
(25^2)
Therefore distance xy = 470 m
By short step excel based start and step program i get around 293 m distance
Hmm I see I will try to work it out , thanks for the help
The program consides short velocity changes, adding the derived distance changes as it goes.
Consider the velocity change between 10 m/s and 11 m/s, calculate the (net) driving force at each velocity, find the average (net) force, calc the acceleration from : a = f net ave / mass, then use newons laws to calculate the distance traveled between those two velocities.
Add the steps as you go for a running distance.
Hint: i used steps of 0.01 metres / second, and 1500 ish lines of program
Sorry am not really sure about calculus part
But maybe this is the solution
Driving force =1200*acc - 500N
P=fv
20kw=1200*acc - 500N
Acc=2.083
2.
Driving force =1200(2.083)- 500
=1999.6
Fs=0.5mv^2 - 0.5 mu^2
S={ [(0.5)(1200)(25^2)-[(0.5)(1200)(10^2)]} / driving force
Therefore distance =157.6m
Work= 20kw x 30.5
=610kj
Net =kinetic energy
610kj - (500N x distancexy )= (0.5 ) (1200) (25^2)
You are almost right.
net work done = change in KE
and the car already has some KE at the beginning of that 30.5s time interval.
I don't think that this is correct, being as the force that propels the car forward is not constant.
P=fv
Acc=2.083
A power output is not a force.
Ao
So the 2nd answer i gave should be the correct one ?
Thanks
No, because you introduced other mistakes there. :frown:
Fix the one I commented on.
Yea I thought the 2nd answer was correct because it fixes the change in kinetic energy as you had pointed out
P=fv
Acc=2.083
you wrote, correctly, P=F v, but that's not what you did in the next step. What happened to v?
Owh sorry I made a typo I did include the v in the calculation
V = 10 at x
20k=(1200*acceleration - 500 ) (10 ) Acc= 2.083
V = 10 at x
Subtracting the 500N resistance made the acceleration go up. Does that seem reasonable?
