Constant Speed of Light: Low Speed Explained
In summary, the constant speed of light at low speeds is due to the fact that all relativistic effects occur at all speeds, even if they are too small to measure with current technology. Additionally, the velocity transformation formula shows that the speed of light is invariant for any relative velocity. This means that the phase velocity of electromagnetic waves is always the same, regardless of the velocity of the light source. Finally, the motion of the measuring equipment at low speeds can affect measurements due to time dilation and length contraction, but the motion of the lab itself has no effect on its own measurements.
grounded
85
I understand the relativistic effects at high speeds, what accounts for the constant speed of light at low speeds?
Example... If I travel towards a beam of light at 25 MPH, I will still measure the light as traveling towards me at the speed of light and not the speed of light plus 25 MPH.
It's the same for all speeds.
Likes vanhees71 and sysprog
All relativistic effects occur at all speeds. It's just that the departure from Newtonian physics gets greater the higher the speed, but it is always there at all speeds, even if it's too small to measure with current technology. As our technology improves so does our ability to detect it at ever lower speeds.
The velocity transformation formula is:$$u' = \frac{u + v}{1 + \frac{uv}{c^2}}$$Where ##u## is the speed being transformed from one reference frame to another with relative velocity ##v##. If we take ##u = c##, then:
$$u' = \frac{c + v}{1 + \frac{v}{c}} = c\frac{1 + \frac{v}{c}}{1 + \frac{v}{c}} = c$$And, we see that the speed ##c## is invariant for any relative velocity ##v## - even if ##v## is only ##25 \ mph##.
Likes Dale, sysprog and vanhees71
There is no such thing as "high speeds" or "low speeds". There are only high or low speeds relative to something. Right now you are moving at "high speed" relative to cosmic ray particles that are bombarding the Earth or neutrinos coming from the Sun.
In short, no object has just one "speed" so it is meaningless to ask whether relativistic effects happen "at low speeds" as well as "high speeds".
Likes sysprog and vanhees71
Just to expand a little on what PeroK wrote, the formula he gave is correct at all speeds, but approximates to the familiar Galilean ##u'=u+v## when both ##u## and ##v## are much less than ##c##. But you're talking about light speed, which is not less than light speed - i.e., one or other of ##u## and ##v## is not much less than ##c##. So you can't use the Galilean approximation for light, ever, whatever the speed of the observer.
Thank you for the replies, however that’s not exactly what I was looking for, but I am aware of all of that, at least I think I am. My social skills are not the best, let me rephrase my question….
If I were to calculate the speed of light by measuring the frequency and wavelength of light coming from a source that is at rest relative to me, I will get the speed of light.
If I travel towards the source at a slow 25 MPH, the frequency and wavelength will have to change in a way that still equals the speed of light. Since the relativistic effects are non-linear, how does it account for the linear change in speed? If I travel at 1 MPH towards the source, the speed of light must change 1 MPH relative to me, and 2 MPH for 2 MPH and so on. What am I missing?
The relativistic Doppler effect formula is easily Googled.
No - this is exactly what @PeroK showed you. The speed of light does not change when you apply the correct velocity addition formula. Whatever speed you do, the speed of light remains invariant because velocities do not add as you are saying they do here.
Likes sysprog
Yes. They do. Have you looked at the math?
Instead of waving your hands, you should look at the math.
Likes sysprog and PeroK
grounded said:
What am I missing?
A knowledge of SR?
Likes weirdoguy, sysprog and berkeman
The relation between the frequency and wave vector of em. waves in a vacuum can be written in terms of a relatcistically covariant formula,
$$\omega^2/c^2-\vec{k}^2=0.$$
This means that in all inertial frames ##\omega/|\vec{k}|=c##, i.e. the phase velocity is always the same, no matter what's the velocity of the light source.
Likes sysprog
Clocks and rulers account for the measurement result being c, when measuring the speed of light.
At low speeds clocks are much more important than rulers. I mean clocks and rulers bolted on a slowly moving lab. Motion of the lab has a small effect on the length of the ruler, large effect on the synchronization of the two clock at the ends of the ruler.
  • Skeptical
Likes PeroK
Motion of the lab relative to something else has no effect at all on measurements made by the lab itself.
If we want to answer the question that was asked, we need a moving measuring equipment. And moving rods are contracted.
Well I am just guessing here that it's the measuring system that is moving at the slow speed that OP mentions.
Oh yes, OP say that OP moves and measures. So there must be an observer that observes OP moving and measuring, and the question is why according to this observer the result of OP's measurement is c.
And the answer is that the OP's measurement result is an invariant, because, as I said, motion of the OP and his measuring devices relative to something else has no effect at all on the OP's own measurements. It has nothing whatever to do with any length contraction or time dilation that someone else sees the OP having.
The OP later, in post #7, clarified his question, saying his concern is motion relative to the light source. That is a different question and has a different answer than the one I gave above (and several posters have given the answer in response to post #7), but the answer still has nothing whatever to do with how the OP is moving relative to some other observer.
Likes vanhees71
You are missing to choose the longitudinal relativistic Doppler formula over the classical Doppler formula.
The Lorentz transformation for energy is
##E' = \gamma (E - \frac{v}{c} * cp_x)##
With ##cp_x=c \frac{h}{\lambda} =hf = E## for a photon moving in x-direction follows:
##f' = f \gamma (1 - v/c) = f \frac{1}{\gamma (1 + v/c)} ##
##\lambda ' = \lambda \frac{1}{\gamma (1 - v/c)}= \lambda \gamma (1 + v/c)= c / f'##
The time-dilation factor ##\gamma = 1/\sqrt{1-v^2/c^2}## makes it possible, that the speed of light is the same in both frames without a contradiction to the principle of relativity. You are wrongly assuming Newton's absolute time.
In your example, it the source is at rest in the primed frame and you in the unprimed frame, and ##v= +1\text{MPH}##, you would measure:
## f = f' \frac{1}{\gamma (1 - v/c)}##
##\lambda = \lambda' \gamma (1 - v/c)##
Likes Grinkle and vanhees71
That is correct.
You're contradicting yourself. First you say the speed of light doesn't change, then you say it does!
What you are missing is the foundation and the logic used to derive the consequences. The speed of light is the same for all observers. That's part of the foundation. You seem to accept the consequences, such as length contraction and time dilation, but you don't seem to want to accept the foundation.
Thanks guys for all the replies and help, I got what I was looking for.
You can close this thread.
Likes berkeman
1. What is the constant speed of light?
The constant speed of light refers to the speed at which light travels in a vacuum, which is approximately 299,792,458 meters per second. It is denoted by the symbol "c" and is considered a fundamental constant in physics.
2. Why is the speed of light considered constant?
The speed of light is considered constant because it does not change regardless of the observer's frame of reference. This was first proposed by Albert Einstein in his theory of special relativity and has been confirmed by numerous experiments.
3. How is the constant speed of light related to the theory of relativity?
The constant speed of light is a key component of the theory of relativity. It is one of the two postulates of special relativity, which states that the laws of physics are the same for all observers in uniform motion and that the speed of light is constant in all inertial frames of reference.
4. Can the speed of light ever be exceeded?
According to the theory of relativity, the speed of light is the maximum speed at which all matter and information in the universe can travel. Therefore, it is not possible to exceed the speed of light.
5. How does the constant speed of light affect our understanding of time and space?
The constant speed of light has significant implications for our understanding of time and space. It is the basis for the concept of time dilation, which states that time passes slower for objects in motion relative to an observer. It also plays a role in the theory of general relativity, which explains the curvature of space-time.
