Constructing a Deck with Beam supports
  • Thread starter Thread starter srw2104
    Beam
The discussion revolves around the construction of a bridge-like structure in a backyard, specifically focusing on the design and sizing of I-beams to support a load of 2000 lbs from a lawn mower across a 30 ft span. Participants explore various structural considerations, including beam theory, load distribution, and material choices, while addressing both theoretical and practical aspects of the design.
  • One participant suggests researching beam theory and applying formulas for beams supported at both ends, emphasizing the need to consider both distributed and concentrated loads.
  • Another participant proposes using laminated 2x boards to create strong beams, resting on footers, and discusses the importance of splicing joints properly.
  • There is a suggestion to place I-beams at the one-third points of the cross span for maximum strength, while another participant contests this, proposing one-sixth points instead.
  • A participant mentions the need to account for the taper of I-beam flanges when attaching cross timbers and suggests using special clamps for this purpose.
  • Concerns are raised about the potential buckling of I-beams if both ends are bolted down, advocating for one end to be free to expand.
  • Calculations are shared regarding the weight of timber decking and I-beams, including moment calculations and required section modulus for the design.
  • Another participant discusses the importance of ensuring that the wheel centerpoint of the lawn mower does not deviate significantly from the I-beam centerline to maintain structural integrity.
Participants express differing opinions on the optimal placement of I-beams and the adequacy of various lumber sizes for supporting the load. There is no consensus on the best approach, and multiple competing views remain regarding structural design and calculations.
Participants note the need for further calculations and considerations regarding load distribution, material properties, and structural integrity, indicating that assumptions about load behavior and material performance may vary.
srw2104
Hello all,
I am currently trying to figure out a cheap way to build a "bridge" that will go in my back yard. It will primarily be used to drive my 2000lb lawn mower over a small creek. I want to support it with 2 to beams at a 30 ft span as I will rest 2x8 or 2X10 pieces of wood on it. It will be flat and just have a small incline on each side to get on and off it. I need to figure out what beam size to use (preferably I-beam). Any formulas or any advice that applies to my situation helps a lot. Thank you in advance. I have also attached a sketch so you can visualize what I am discussing.
Have you google Beam Theory? You should get quite a few hits (just ignore the ones about Bernoulli).
Then, look for the formulas for the cases of a beam supported on both ends.
Then, pick your beam (moment of innertia)
Because you are going to operate on the elastic part, you can apply superposition and so, you need to apply the formula twice for two different loads and add the deflections up ...keep increasing your I-beam until an acceptable deflection in the middle...1 inch? 2 inch? I don't know ...I took some classes over 20 years ago...don't remember much..
So, first, you need to apply a distributed load due to all the pieces of wood that you are planning to put on the bridge...there is a formula for this
Second, you need to apply a concentrated load due to the lawn mower and place it in the worst place...in the middle of the bridge...there should be a formula for this already , too.
If you are planning on using at least two I-beams, don't forget to divide the forces (weights) by 2 when applying to the formulas.
Hope this helps.
The way you've drawn the picture, it appears you are thinking of having the 2x boards span the 30 foot gap across the stream. Laying 2x boards flat, spanning from I-beam to I-beam will not provide a useful beam/bridge. 2x boards laid flat will not support much of a load.
Consider making the bridge with 2 beams spanning the stream, with 2x boards spanning between the beams to form the roadway. The beams might be fabricated from 2x boards on edge, with several laminated together to form strong beams. Those beams would then rest on footers on each side of the stream. The footers could be the I-beams, or more economically they could be concrete blocks, setting on a pad to distribute the loading into the ground. You would not need to have the blocks run from beam to beam.
I've not run numbers for these beams, but think of each beam being formed by laminating 4 2x10's. You would need to splice about 3 2x10 to get the length. The splice joints could be made by butting them end to end and sandwiching/tying them to the adjacent boards with long screws or bolts. Splice joints would need to be staggered such they are some distance apart.
The roadway could then be laid either on top of the beams, or set on a ledger board fastened to the side of the beams. If the bridge is fairly narrow (4 ft?) you may be able to just use a single layer of 2x. However, I suspect you will need to at least double them up, and tie (screw) the layers together. Or you might consider fastening a 2x4 to the underside of each roadway piece to form a 'T' beam.
Some calc's do need to be run, as suggested by Gsal.
Oh, my, I just read DickL's message and made me look at the picture...
I just noticed that my description of the problem does not correspond to the way you have drawn the bridge...instead, I went under the assumption that you were going to use the I-beams to span the width of the stream...just like DickL suggests...that's the way to go.
So, please read my post previous post with that in mind and it should make much more sense.
So, think of your bridge like an upside down railroad track...instead of the I-beams on top of the sleepers, you want to put 2 I-beams that span the stream (one end of the I-beam is on one side of the stream and the other one on the other side) and on top of the I-beams you want to put sleepers across so that you can drive over them...
Thanks. And yes, i realized my first idea didn't make very much sense. I do plan to go with what you and DickL are talking about. I now believe I have to tackle two problems:
1. determine the size of planks required to carry a 2000lb dynamic load across a 6' span since that is how far apart I plan to place the two I-Beams
2. determine the size of a 30' I beam required to carry the weight of the planks plus a 2000# dynamic load mid-span
Any suggestions, formulas, calculations...anything at all is much appreciated
Here is a nice tutorial
http://paws.wcu.edu/radams/Intro_to_Beam_Theory.pdf
By the way, if you set your two I-beams as much apart as the tires of your lawn mower, it is almost as if your 2x8's or 3x6's (a bit thicker) wouldn't even have to come much into play since they would simply have I-beam support right underneath of where the load is being applied on top of them...even if you are a bit off, I wouldn't worry much about that...we would be talking about a 500 lb per point.
Also, another refinement when applying the point load on the I-beam, you need to apply two 500 lb point loads as much apart as the distance between the front and rear axis of the lawn mower to one I-beam and make sure it can withstand...
For maximum stength your I beams should be placed at the one third points of the cross span, not at the edges.
How are you going to attach the cross timbers? You need to be aware that the inner flange surfaces of I beams are not parallel they taper.
You can get special clamps google 'lindapter' for this.
You must bolt down one end only of the I beams, leaving the other free to expand. If you bolt down both ends they will buckle.
Studiot said:
For maximum strength, your I-beams should be placed at the one-third points of the cross span.
That appears to be incorrect. For maximum strength, the I-beams probably would be placed at the one-sixth points of the joists (or deck beams), measured from the joist ends. (However, it might depend on the vehicle wheel base.)
Hello, nvn I suppose it depends upon the way you usually look at these things.
I normally consider the half section for symmetrical loading.
Anyway an overhang of one third of the half or one sixth overall is not quite theoretically perfect but quite close.
Since the vehicle is likely to have wide tyres and or rollers I have modeled a distributed load for the cross section.
You can see the theoretical best place for a simple support is 0.414 times the hald width in from the end.
srw2104: You must establish not only a spacing between the two I-beam centerlines, but also the length of your deck lumber, and the maximum amount a wheel centerpoint can deviate from directly above an I-beam centerline. Assuming your lawn mower wheel can deviate from directly above an I-beam by up to 450 mm outboard, then 38 x 184 mm (or 38 x 235 mm) lumber would be inadequate. It appears 89 x 89 mm southern pine lumber, grade number 2, might be adequate, assuming the tensile side of the lumber cross section (directly over an I-beam) is not drilled nor damaged.
Some quick calculations run as follows:
Wt of 2 inch thick 6 foot wide timber decking 6 foot per I beam
[tex]\begin{array}{l}<br /> \frac{1}{2}*6*\frac{1}{6}*30 = 15cuft \\ <br /> 15cuft\,@\,40lbs/cuft = 600lbs. \\ <br /> \end{array}[/tex]
Trial Wt of I beam @ 100 lbs per foot = 100 * 30 =3000lbs.
This design will be moment controlled with max pointload of say 1500 lbs in centre
Max moment is
[tex]M = \left\{ {\frac{{3600*30}}{8} + \frac{{1500*30}}{4}} \right\}lbs - ft[/tex]
=297,000 lbs-ins
The required section modulus at working stress of 20,000 psi is therefore
[tex]\frac{{297000}}{{20000}}in{s^3} = 14.85in{s^3}[/tex]
I do not have many american standard tables but what I have suggests that a
20 x 7 x 95lbs/ft beam would just suffice (S=14) since I have deliberately overestimated for the trial.
A 24 x 7.875 x 105.9 lbs per ft would be safer at S=20
You should get these calcs professionally checked, they can probably be refined further.
You should also note the approx weight of a suitable I beam at nearly 1.5 tons.
Studiot: If you get a chance, would you be able to state the I-beam size listed in post 11 as a Euronorm standard HE size, so we may know what size you are referring to?
I was rather rushing last night and looked in the wrong column.
When I look in the correct one I see that a much smaller I beam will suffice
An 8 x 4 x 23lb/ft looks better.
This reduces the beam weight to 700 lbs
Thus the max moment is now 166500
and the required section modulus greater than 8.3
The 8 x 4 has a section modulus of 16 (correct this time).
The spare capacity would leave room for bolts, braces and what have you.
If you need a thicker deck then things may change again.
Further refinement is possible.
@nvn
I have worked this in imperial units because I think the OP is in America, where they still use proper units.
I do not have any information about Eurocodes, but can tell you that the 8 x 4 is roughly equivalent to a BS5950 or BS5400 203 x 102 I section.
Studiot: It appears you are referring to an imperial I-beam called S8 x 23. Your maximum moment is slightly incorrect. You might want to check your numbers.
More importantly, your I-beam is overstressed. The laterally-unbraced length is 9.14 m; but it appears you ignored lateral-torsional buckling, which is a leading cause of steel structure failures.
The I-beam would instead need to be, at least, a European standard HE 200 AA, or an HE 180 A, or an imperial W8 x 24.
Yes you are right its 193500, making the required modulus 9.675.
The American 8 x 4 I section will easily accommodate this.
If this were a real design it would all be taken care of in the next cycle, note the allowance above.
No, as I mentioned in post 14, the S8 x 23 is overstressed. There is nothing really stable to brace to, in this particular structure, if you use an unstable I-beam. Regardless, for approximately the same mass per unit length, one can instead specify a stable I-beam (listed in the last paragraph of post 14), instead of an unstable I-beam.
No,
Conventional web stiffeners?
No, just buy the correct I-beam size (or larger), to start with. And then you do not need to waste time and money trying (unsuccessfully) to jury-rig an inadequate design. Even if srw2104 gets an I-beam 2 to 7 kg/m larger than the minimum required size, no problem.
This was all very useful information...thank you for all the help. It is much appreciated
10K
