Continuity of a function implies its existence in the neighbourhood?
The continuity of a function ##f(x)## at a point ##x=c## necessitates that ##f(x)## is defined in an open neighbourhood around ##c##. If ##f(x)## were undefined in this neighbourhood, the limit ##\lim_{x\to c}f(x)## could not exist, contradicting the definition of continuity. Therefore, it is sufficient to state that "##f(x)## is continuous in an open subset ##U## of ##\mathbb{R}##" without needing to specify that it exists in that subset, as the definition of continuity inherently requires the function to be defined in its domain.
  • Understanding of the ε-δ definition of limits
  • Familiarity with the concept of continuity in real analysis
  • Knowledge of function domains and their implications
  • Basic understanding of topological spaces
  • Study the ε-δ definition of limits in detail
  • Explore the implications of function domains on continuity
  • Learn about continuity in topological spaces
  • Investigate examples of functions with discontinuities, such as ##f(x) = 1/x##
Mathematics students, educators, and anyone studying real analysis or calculus, particularly those focusing on the concepts of continuity and limits.
Happiness
Suppose ##f(x)## is continuous at ##x=c##. Does this imply that ##f(x)## exists in an open neighbourhood of ##c##?
I believe it does. If ##f(x)## is continuous then ##\lim_{x\to c}f(x)## exists. But if ##f(x)## is undefined for some values of ##x## in the ##\delta##-neighbourhood of ##c##, then we cannot say ##|f(x) - L|<\epsilon## for ##0<|x-c|<\delta##, contradicting that ##\lim_{x\to c}f(x)## exists. So there must exist a ##\delta>0## such that ##f(x)## is defined for all values of ##x## in the ##\delta##-neighbourhood.
https://en.wikipedia.org/wiki/(ε,_δ)-definition_of_limit
If so, does this mean that it is enough to just say "suppose ##f(x)## is continuous in an open subset ##U## of ##\mathbb{R}##" instead of "suppose ##f(x)## exists and is continuous in an open subset ##U## of ##\mathbb{R}##"? (which is what is stated below)
http://calculus.subwiki.org/wiki/Clairaut's_theorem_on_equality_of_mixed_partials
Why not?
mfb said:
Why not?
Suppose ##f(0.1)## is undefined. Then ##|f(0.1)-L|=|##undefined##-L|## and so it cannot be less than ##\epsilon##.
But you never want to consider that expression in the first place, because you evaluate eps/delta only for x-values where the function is defined.
Is
##|##undefined##-L|<\epsilon##
vacuously true?
No, the problem does not even come up. The equation has to be satisfied only for all x in the domain of the function which are closer than delta to the given point.
every function defined on a topological space that consists of a single point is continuous.
The definition of continuity includes the condition that ##x## be in the domain of the function. If you were to take a function defined on ##\mathbb{Q}## such that ##f(x) = 1## for all rationals, then that function (defined on the rationals) is continuous. You cannot consider hypothetical function values for points not in the domain.
Another good example is that ##f(x) = 1/x## is continuous on ##\mathbb{R}-\{0\}##. This is interesting as you will find references to the "discontinuity" of ##1/x## at ##x=0##. What that means technically is that you cannot extend ##1/x## to be a continuous function on ##\mathbb{R}##. But, technically, ##1/x## is a continuous function: there is no point (in its domain) at which it is discontinuous.
As another example, if you consider f(x) as function over the real numbers and study the continuity at x=0, you don't even think about plugging in imaginary numbers for x. Why? Because those imaginary numbers are not part of the domain of the function.
