Continuity of Hamiltonian at separatrix in action-angle variables
The discussion centers on the continuity of the Hamiltonian at the separatrix within the action-angle formalism. It is established that the Hamiltonian, defined as a piecewise function, may not be continuous at the separatrix due to the peculiar behavior of action variables. The transition between the oscillatory Hamiltonian \( H_{osc} \) and the rotational Hamiltonian \( H_{rot} \) does not necessarily imply continuity, as the action variable \( J \) behaves unpredictably at this critical energy level. A proof or further resources are sought to clarify these concepts.
  • Understanding of Hamiltonian mechanics
  • Familiarity with action-angle variables
  • Knowledge of piecewise functions in mathematical analysis
  • Concept of separatrix in dynamical systems
  • Research the properties of action-angle variables in Hamiltonian systems
  • Study the concept of separatrix and its implications in dynamical systems
  • Explore continuity and differentiability in piecewise functions
  • Examine canonical transformations in Hamiltonian mechanics
Physicists, mathematicians, and students studying Hamiltonian dynamics, particularly those interested in the behavior of systems at separatrices and the implications for action-angle variables.
giraffe714
TL;DR
Because the action variable is not necessarily the same between oscillatory and rotational motion, how can it be ensured that the Hamiltonian is differentiable, or at least continuous at the separatrix?
As said in the tl;dr: is the Hamiltonian necessarily differentiable (hence continuous) at the separatrix in the action-angle formalism? After all, the action variables are different depending on the type of motion. As far as I know the Hamiltonian H = H(J) can be found by inverting J for E, and the most obvious thing I could come up with (which may just be where I'm going wrong) is to define H as a piecewise function, with:
$$ H = \begin{cases} H(J_{osc}) & E < E_{osc} \\ H(J_{rot}) & E > E_{rot} \end{cases} $$
But (a), it isn't defined at the separatrix, mainly because I'm not entirely sure how I would go about calculating J at the separatrix as, from what I can understand, at that energy there's basically a 50/50 chance the next "cycle" will be rotation or oscillation (hence, what bounds should be used?) And (b), even if for example ## J_{sep} = J_{rot} ##, would the Hamiltonian then necessarily be continuous? Again, perhaps it's the way I'm thinking about the Hamiltonian as a piecewise function, perhaps there's a better way to combine the two. While my intuition for the fact that, yes, it should be continuous is there: for example, for p = p(x, E) the energy slowly climbs up in oscillations until in reaches the separatrix, at which there is a point where p = 0, and then that bottom-most part of the separatrix where p = 0 smoothes itself out and rises to become rotational motion. And of course this shouldn't change in the action-angle formalism because after all it's a canonical transformation. But despite having this intuition, I think it's important to have a proof for a more concrete understanding. Might be just missing something though, in which case do point that out. But if I'm not just making a mistake, please point me to a resource which explains this or maybe gives a proof sketch. Thanks!
So I went down a bit of a rabbit hole and turns out, from what I could gather:
a) The action variable behaves strangely at the separatrix.
b) The transition between ## H_{osc} ## and ## H_{rot} ## need not be continuous, which is okay because I completely misinterpreted what kind of continuity I was looking for - I thought the discontinuity between ## H_{osc} ## and ## H_{rot} ## was going to make the partial derivatives of H at a *set energy level* be ill-defined, which is not the case. Whoops.
  • · Replies 0 ·
  • · Replies 26 ·
