Continuously Variable Transmission Idea
69 replies · 12K views · last reply
AlexB23 said:
So the guy is wrong? He built an over complicated clutch mechanism that slips?
As he defined it, the input and output are the differential carriers. My thoughts are that it outputs whatever is input, no matter what.
He said:
rajava007 said:
I made a CVT (Continuously Variable Transmission) that uses two differentials to first split power between two gear ratios based on torque (1:1 and 2:1), and then recombine the separate rotations into a single output via a second differential. Yes, I did test this out, and it works.
I then replied in post #10 explaining my position which has remained unchanged. He then replies:
rajava007 said:
Thank you so much! I have been stuck around this point for a very long time! So in summary, all this does is vary the speed?
So which is it? In one post he claims it was tested and works. In another post he acts as if he doesn't understand it. Asks if it just varies speed when I clearly explained that it does not. As far as your comment about slipping, there are other posters in this thread that have talked about slipping, or at least I assume they were eluding to it by talking about friction. @jack action posted something in post #8. I apologize if I misinterpreted. Meanwhile, the OP has not been back. 🙄
Simple rule: When the OP does not come back, he realized his idea fell flat.
  • Haha
rajava007 said:
*Step 12 shares that the CVT might require friction in some places to work*
There was a Daf motor car (Variomatic?) that used a belt which operated between a pair of cones which acted like a variable diameter pulley. There was a fair amount of friction there, I believe.
My example of the automotive differentials should explain why the differential carrier speeds have to be the same no matter what.
But isn't the point of a differential that the two output shafts would be able to turn at different speeds - to allow cornering without wheel slip? The share of the output power would also vary between the shafts.
A similar system is used in some all wheel drive transmissions where the front and reads wheels are arranged to have different torques from the 'third differential' driving the transmission shaft to the rear. I think the ratio doesn't change, though.
Look at what the OP has defined as the input and output of the setup in question. What differentials are or aren't supposed to do is irrelevant. We have been given a combination of gears, etc. and the input and output defined. That's what we have to work with.
Baluncore said:
@rajava007
Can you please check that when you turn the input on your model, the output is locked to turn at the same rate.
Yes, i can
sorry... Im just a rising highschooler who stumbled upon an idea that I didn't fully understand, hence I came here. For my recent absence I do apologize due to third quarter testing. On that note, would it be able to "dumb-down" some terms where possible? Again I apologize for the misunderstandings.
We would love to help you with your project. It's good to be curious and wanting to build things. Good on you.
So to help us help you, please answer the questions you've been asked here in your thread. Thank you. :smile:
Thank you! As for claiming it works, I've added a video of using the differential will no force and then applying force to the output. The input is the gray carrier gear and the output is the black carrier gear. I appologise for the quality as I had to zoom in, and could only make the file size so large.
VIDEO_LINK
I hope this helps!
Thread reopened. I made a simple schematic sketch of what I think that mechanism is.
Shaft 1 is geared to shaft 2. Shaft 3 is geared to shaft 4. Shaft 1 is connected to shaft 3 through a differential. Shaft 2 is connected to shaft 4 through a differential.
Turning shaft 1 turns shaft 2 because they are geared together. Turning shaft 3 turns shaft 4 because they are geared together. The speeds of shafts 1 and 3 are independent of each other because of the differential between them. The differential carrier rotates at a speed proportional to the difference between the speed of shaft 1 and the speed of shaft 2. The same for shafts 2 and 4. One or the other of the differential carriers can be turned or braked to affect the speeds of the shafts.
All of this is difficult to see because of the large amount of friction in the system.
This is useless as a transmission, but useful as a fidget spinner. It's a neat toy and should be fun to play with.
All is good.
I named things differently to @jrmichler
The input differential drive is X, with axle shafts A and B.
The output differential drive is Y, with axle shafts C and D.
X (grey) = A (green) + B (red) ; input diff
A is geared to, C (magenta) = A / 2 ;
B is geared to, D (yellow) = B * 2 ;
Y (white) = C + D ; output diff
Now we fix the input X = 100 ; constant speed, call it say % or RPM.
We brake some shaft to control A (green), the horizontal axis.
The CVT ratio is then Y (white) percent.
Zero and negative output speeds are available.
We can apply a braking force to part of a differential to control output speed. This is equivalent to using a series resistor as a voltage regulator. It only works with a constant load.
A differential distributes torque equally, the electrical analogy is current. A current shunt across a motor is equivalent to a brake on a shaft. Voltage is the analogy of RPM, the brake is not in series with the load, as that would be called a clutch.
Controlling torque through the use of brakes is a dynamic exercise, there is no set and forget.
When I am driving a tractor with independent brakes, the differential shares the torque equally to left and right. If I brake on one side, the total torque passed by the differential to that side remains the same, but the brake torque is not available for traction to the wheel on that side.
When I spin a wheel, usually the high side on a hill, the torque to both sides is reduced. I brake on the slippery side, to mirror the brake torque to the other side, in the hope that side will grip, and so pull me out of trouble.
That was my point.
Not sure about that. The differential doesn't 'know' what it's supposed to do; it just obeys the 'rules'. Using this system to vary speed could involve dissipating a lot of energy elsewhere, to vary the power delivered to the 'output'. A brake of some sort would achieve what was wanted but it would be a bit like comparing a series resistor and a VARIAC transformer. When you get down to it, the power throughput will only be 100% of what's supplied for one speed ratio if the velocity ratio of all the gear pairs doesn't change.
The OP's idea is based on very established principles. If it were a go-er then we'd find it in a lot of vehicles already.
I'm not sure what the idea actually is. I don't think the OP ever said specifically that the way to achieve varying speed is to apply braking in one place or another. That has been implied by other posters. I've found the OP's posts somewhat confusing and the video showed virtually nothing useful. I don't need a video demo to know what this gadget will and won't do. It's not that complicated yet.
As far as being a go-er, differential type power combiners are found in transmissions all over the place usually in the form of a planetary. They do not allow the speed to vary by braking. They use hydrostatic drive on one input and power direct from the engine on the other. When I say direct, that's not literally direct as there will be gearing with clutch packs and planetary sets that function to provide ranges. The end result is still a continuously variable output. Shifting between ranges is not felt by the operator.
I took it that the OP's hope was for torque and RPM at the input, be passed to the output as a torque, independent of the output speed. That would indeed be a useful device, if only it was possible without braking. The hope of an automatic CVT is illusory, very much like a PMM or an FE generator.
Conceptually, energy could propagate down both sides, with a doubling or a halving of the speed, so the blended paths output could match the energy input. Unfortunately, the mechanism is too complicated to be understood without an engineering analysis. It makes an excellent fidget spinner for the brain.
The first realisation people have, tends to be grabbed, while deeper analysis is avoided. As an example, there is a loop around which energy can flow in either direction. One way around would be for small gear A, to drive big C, to small D, to big B. Obviously, without the complication of the diffs, such circular paths, forever halving or doubling the speed, would be a contradiction, that would lock the mechanism solid. The mechanism would be locked, but only if the carriers of both diffs were also locked.
Yes but not variable and lossless.
Same for a lever, too.
Well of course. That's what I've tried to say all along and I've explained that additional component groups are required to get to a fully functional continuously variable transmission and they do exist. Of course they are not lossless as nothing is.
This thread has turned into a train wreck and it is a mystery to me why this is the case.
Other than the title of this thread and the fact that there is a quite clear image of the device I'm not sure of anything else the OP has said or expects other than a defined input and output.
I haven't gone through any math. I simplified it by thinking about it as if it were two identical automotive rear axles with the same ratios and same wheel sizes rolling along.
The input and output will always be the same. Saying they aren't is like saying that 1 + 1 = 2 except when it doesn't.
This thread has fully answered the OP's original question, then circled around until all sight of the OP was lost. Thanks to all who contributed. Thread closed.
  • Haha
rajava007 said:
Below is a power diagram:
And now this is the diagram of the CVT I made without edits ontop:
My initial idea was that it's just a 1:1 transmission, because it's symmetrical: If you turn it around by 180°, you have the same gearbox but output and input labels are now swapped. But since differentials are counterintuitive and I had LEGO laying around, I just built it from exactly the same parts, but added shafts to the input/output (yellow crosses) to make their rotation clear.
Disappointingly it was exactly what I initially expected: A boring 1:1 transmission that merely reverses the direction (the yellow crosses rotate opposite to each other). Contrary to some claims in this thread, it is not possible to hold the output static, while turning the input continuously.
However, since it's all bendy plastic and loose gear meshing, it's possible to turn the input by about 45° while the output is held static, before it locks up or gears start skipping teeth. This is what might have confused the OP, who didn't use input/output shafts, and was applying forces to the differential carriages with slipping fingers.
But no surprise without an input of unobtanium, I think. Lego has no appropriate parts, afaik.
A.T. said:
But since differentials are counterintuitive ...
A differential distributes power to the two axle shafts by sharing torque equally. A differential combines power from the two axle shafts by summing RPM. This mechanism transmits output torque back to the input differential, which influences the RPM of the two gear trains.
I don't understand what you mean, but @Averagesupernova was right here:
It looks like each differential carrier wil rotate at identical speeds no matter what.
I do not believe that your assumption is the case.
It's seems you are overcomplicating things.
You need to consider what happens when you drive the two carriers at different relative speeds. Take a look at the RPM (or speed %) plots in post #42, and you will see that nothing rotates at an identical speed, except where two lines cross. No one line remains on top of another line. The differential carriers can rotate at different speeds, they can be at the same speed, one or both can stop, or they can counter-rotate.
Complication is required only sufficiently to model the system, any complication beyond that is unnecessary. If you do not understand the analysis, then how can you know your analysis of the model is complete.
