yttuncel
- 28
Torricelli’s law says that if you drain a tank like the one in the figure shown, the rate y
at which water runs out is a constant times the square root of the
water’s depth x. The constant depends on the size and shape of the
exit valve.
http://imageupload.org/thumb/thumb_136882.jpg
Suppose that for a certain tank. You are trying to
maintain a fairly constant exit rate by adding water to the tank
with a hose from time to time. How deep must you keep the water
if you want to maintain the exit rate
a. within 5.7 L/min of the rate y0=28.3L/min
b. within 2.8 L/min of the rate y0=28.3L/min
I could not understand neither the question nor the method i should use. Should it be done via epsilon-delta method? Or simply by differentiating ?
