What conditions guarantee convergence of Newton's method for approximating pi/2?
This discussion focuses on the conditions necessary for the convergence of Newton's method when approximating $\frac{\pi}{2}$ using the function $f(x) = \cos(x)$. It is established that starting values $x_0$ must be within the interval $(0, \frac{\pi}{2})$, and the first iteration $x_1$ must be closer to $\frac{\pi}{2}$ than $x_0$ for convergence to occur. The discussion emphasizes that a larger initial value, while still less than $\frac{\pi}{2}$, will enhance convergence speed, as the tangent line's intersection point will fall on the right side of the root.
  • Understanding of Newton's method for root-finding
  • Familiarity with trigonometric functions, specifically $\cos(x)$
  • Knowledge of convergence criteria in numerical methods
  • Basic calculus concepts, including derivatives and error analysis
  • Study the convergence properties of Newton's method in detail
  • Learn about error analysis in numerical methods
  • Explore the implications of the derivative's behavior on convergence
  • Investigate alternative root-finding methods for comparison
Mathematicians, numerical analysts, and students studying numerical methods who are interested in the convergence behavior of iterative algorithms, particularly in the context of approximating roots of functions.
mathmari
MHB
Hey! 😊
I have calculated an approximation to $\frac{\pi}{2}$ using Newton's method on $f(x)=\cos (x)$ with starting value $1$. After 2 iterations we get $1,5707$.
Which conditions does the starting point has to satisfy so that the convergence of the sequence of the Newton iterations to $\frac{\pi}{2}$ is guaranteed? :unsure:
Suppose we start at a point $x_0$ with $0<x_0<\frac\pi 2$. Then the first iteration $x_1$ will be greater than $\frac\pi 2$.
We need that $x_1$ is closer to $\frac\pi 2$ than $x_0$. And if it is, it will be convergent, won't it? 🤔
Why will $x_1$ be greater than $\frac\pi 2$ ? :unsure:
We need that because that would mean that the sequence $(x_i)$ converges to $\frac{\pi}{2}$, or not? :unsure:
Geometrically, the method takes the intersection of the tangent line with the x-axis.
Since $\cos$ has a decreasing slope on $(0,\frac\pi 2)$, that intersection point must be on the other side of $\frac\pi 2$. 🤔
Alternatively, we can look at it algebraically.
wiki explains that we can write the successive errors as:
$$\varepsilon_{n+1} = \frac {- f'' (\xi_n)}{2 f'(x_n)} \cdot {\varepsilon_n}^2$$
where $x_n$ are the successive approximations of a root $a$, $\varepsilon_n=a-x_n$ is the error in that approximation, and $\xi_n$ is a point between $x_n$ and the root $a$.
So if $\varepsilon_1$ is negative, we have that $x_1$ is on the right side of the root. Can we deduce that? 🤔
We're trying to find which starting value we need so that the sequence converges.
We get that if the remaining error converges to zero, don't we? 🤔
wiki explains that we can write the succesive errors as:
We have that
$$\varepsilon_{1} = \frac {- f'' (\xi_0)}{2 f'(x_0)} \cdot {\varepsilon_0}^2= \frac {\cos (\xi_0)}{-2 \sin (1)} \cdot \left (\frac{\pi}{2}-1\right )^2 \approx \frac {\cos (\xi_0)}{-1.6829} \cdot 0.3258 = -0.1936 \cdot \cos (\xi_0)$$
So it is negative when $ \cos (\xi_0)$ is positive, right? :unsure:
mathmari said:
We have that
You have picked $x_0=1$ in which case $\xi_0$ must be between $1$ and $\frac\pi 2$. So for each possible value of $\xi_0$ we have indeed that $\cos (\xi_0)$ is positive.
But aren't we trying the find the $x_0$ that is 'just' sufficient to get convergence?
We have already found that for $x_0=1$ we get convergence. So the $x_0$ that we are trying to find should be smaller, shouldn't it? 🤔
So we want to find the boundary ofall possible $x_0$'s to get convergence, right?
Do we have to use for that the formula for the remaining error?
:unsure:
That's how I interpret the OP.
The formula is for the general case. In our case it should suffice if we solve for the case that after the first iteration we have the same error. 🤔
I got stuck right now.Why does the error have to be the same as the previous error? :unsure:
Then we should have the critical initial starting value.
A bigger starting value (that is less than $\frac\pi 2$) should guarantee convergence shouldn't it? 🤔
Yes. The nearer the starting value is to $\frac{\pi}{2}$ the faster it converges, right? :unsure:
  • · Replies 16 ·
10K
