Conversion to NAND and NOR circuits
  • Context: Engineering
  • Thread starter Thread starter Mo
    Circuits
The discussion revolves around converting logic circuits into NAND and NOR forms, focusing on the application of de Morgan's laws. Participants are exploring techniques for circuit conversion, particularly in the context of a homework problem involving multiple inputs and gate implementations.
  • Homework-related
  • One participant expresses uncertainty about converting a circuit using de Morgan's laws and seeks guidance on techniques rather than explicit answers.
  • Another participant requests clarification on de Morgan's laws and suggests showing the initial solution to facilitate further discussion on circuit conversion.
  • Participants discuss the conversion of AND and OR operations using de Morgan's laws, with one providing examples of how to express these operations in terms of NOT, AND, and OR gates.
  • There is a focus on implementing a circuit with 4 inputs (A, B, C, D) using AND and NOR gates, with one participant suggesting a specific configuration for the gates.
  • One participant points out the requirement for 2-input NAND and NOR gates, challenging the use of a 4-input NOR gate in the proposed solution.
  • Another participant proposes splitting a 4-input NOR gate into two 2-input NOR gates combined with AND operations, referencing de Morgan's laws to justify this approach.
  • There is a discussion about alternative methods, including using 2-input NAND gates as inverters, with one participant appreciating the creativity of the proposed solution.
  • A participant expresses confusion about how to proceed with the next parts of the homework question, indicating a need for further assistance in obtaining the correct boolean expression.
  • One participant shares a resource link related to canonical logic forms and circuit handling, suggesting it may help others in the discussion.
Participants do not reach a consensus on the best approach to convert the circuit, with multiple competing views on how to implement the logic gates and apply de Morgan's laws. The discussion remains unresolved regarding the most effective techniques for the conversion task.
Participants express varying levels of understanding and confidence in applying de Morgan's laws, and there are unresolved questions about the specific configurations of gates needed for the circuit conversion.
Mo
Please see the attatched picture.
I can complete the first part of the question, but i am not sure how i should do the second part.
I would be grateful for a quick explanation or tutorial in how to do this part. I am aware of de Morgan's laws but can't seem to fully apply them to convert a whole circuit.
Im not looking for an explicit answer, I am looking for a technique in how to solve the problem.
Thanks.
Tell us what deMorgan's Laws are, and include an example or two.
Then please show us the solution that you got for the first part, and describe how you would implement it as written with NOT, AND and OR gates.
Then we can talk about how to use deMorgan's Laws to convert to the other form of the circuit...
de Morgan's laws tell us how an AND can be converted to an OR.
Not (A.B.C) = NotA + NotB + NotC
Not (A+B+C) = NotA. NotB. NotC
e.g : Not A+B = NotA . NotB
For the first part i got:
CD + Not(A+B+C+D)
To get this i combined some of the expressions, then finally used demorgan's law as stated above.
:confused:
A + B = Not (Not A . Not B)
A . B = Not (Not A + Not B)
Umm not quite sure if this is correct, or if its what you want!
Thanks for your help so far.
I guess I was looking for the implementation in gates, for the final part of the problem.
We would have 4 input A B C D.
We have a connection from both C and D to an AND gate (which is the CD part)
We also have a connection from all A B C D to a NOR gate. (which is the NOT A+B+C+D part)
Output from these two gates are then connected to an OR gate.
Remember, it said 2-input NAND and NOR gates, so you can't use a 4-input NOR for (A+B+C+D)
In that case i think it would be possible to, applying de Morgan's laws, split up this 4 input NOR gate into two, 2 input NOR gates AND 'ed together.
NOT (A + B) . NOT (C + D)
The output of this would be equal to the 4 input NOR gate.
Regards.
That's pretty cool. I was thinking of the brute force way of using the 2-input NAND as an inverter (hook both inputs together), but your way is more creative and fewer gate delays.
First of all, thanks for your help so far, secondly ... how would I go about tackling those next two parts of the question! It's mainly a case of getting the boolean expression into the correct form. (which I am lost in!)
Regards,
Mo
Sorry, I have to bail from work now. I may be back online later tonight at home, but I'm not sure.
To try to help you more, I googled +minterm +maxterm +nand +nor, and got lots of good hits. Here's one that talks a lot about how to handle the two canonical logic forms (NAND and NOR), along with examples from K-maps to logic gate diagrams. Hope it helps:
http://www.vias.org/feee/karnaugh_09.html
Cheers.
Thanks for the link and all your help. :approve: Good night.
