Converting backward-difference heat equation code to forward-difference method
1 reply · 3K views
ahmedo047
I don't be able to convert the following code(HEAT EQUATION BACKWARD-DIFFERENCE ALGORITHM in the Burden-faires numerical analysis book).I need heat EQUATION FORWARD-DIFFERENCE ALGORITHM C like following code.I don't be able to convert FORWARD-DIFFERENCE the following code .Please help me.
if I write VV = - [ALPHA * ALPHA * K / ( H * H )]; instead of VV = ALPHA * ALPHA * K / ( H * H );in the heat EQUATION BACKWARD-DIFFERENCE ALGORITHM then have I obtained HEAT EQUATION FORWARD-DIFFERENCE ALGORITHM?
Code:
*   HEAT EQUATION BACKWARD-DIFFERENCE ALGORITHM 12.2
*   To approximate the solution to the parabolic partial-differential
*   equation subject to the boundary conditions
*                  u(0,t) = u(l,t) = 0, 0 < t < T = max t,
*   and the initial conditions
*                  u(x,0) = F(x), 0 <= x <= l:
*   INPUT:   endpoint l; maximum time T; constant ALPHA; integers m, N.
*   OUTPUT:  approximations W(I,J) to u(x(I),t(J)) for each
*            I = 1, ..., m-1 and J = 1, ..., N.
#include<stdio.h>
#include<math.h>
#define pi 4*atan(1)
#define true 1
#define false 0
double F(double X);
void INPUT(int *, double *, double *, double *, int *, int *);
void OUTPUT(double, double, int, double *, double);
main()
   double W[25], L[25], U[25], Z[25];
   double FT,FX,ALPHA,H,K,VV,T,X;
   int N,M,M1,M2,N1,FLAG,I1,I,J,OK;
   INPUT(&OK, &FX, &FT, &ALPHA, &N, &M);
   if (OK) {
      M1 = M - 1;
      M2 = M - 2;
      N1 = N - 1;
      /* STEP 1 */
      H = FX / M;
      K = FT / N;
      /* STEP 2 */
      for (I=1; I<=M1; I++) W[I-1] = F( I * H );
      /* STEP 3 */
      /* STEPS 3 through 11 solve a tridiagonal linear system
         using Algorithm 6.7 */
      L[0] = 1.0 + 2.0 * VV;
      U[0] = -VV / L[0];
      /* STEP 4 */
      for (I=2; I<=M2; I++) {
         L[I-1] = 1.0 + 2.0 * VV + VV * U[I-2];
         U[I-1] = -VV / L[I-1];
      /* STEP 5 */
      L[M1-1] = 1.0 + 2.0 * VV + VV * U[M2-1];
      /* STEP 6 */
      for (J=1; J<=N; J++) {
         /* STEP 7 */
         /* current t(j) */
         T = J * K;
         Z[0] = W[0] / L[0];
         /* STEP 8 */
         for (I=2; I<=M1; I++)
            Z[I-1] = ( W[I-1] + VV * Z[I-2] ) / L[I-1];
         /* STEP 9 */
         W[M1-1] = Z[M1-1];
         /* STEP 10 */
         for (I1=1; I1<=M2; I1++) {
            I = M2 - I1 + 1;
            W[I-1] = Z[I-1] - U[I-1] * W[i];
      /* STEP 11 */
      OUTPUT(FT, X, M1, W, H);
   /* STEP 12 */
   return 0;
/* Change F for a new problem */
double F(double X)
   double f;
   f =  sin(pi * X);
   return f;
void INPUT(int *OK, double *FX, double *FT, double *ALPHA, int *N, int *M)
   int FLAG;
   char AA;
   printf("This is the Backward-Difference Method for Heat Equation.\n");
   printf("Has the function F been created immediately\n");
   printf("preceding the INPUT procedure? Answer Y or N.\n");
   scanf("\n%c", &AA);
   if ((AA == 'Y') || (AA == 'y')) {
      printf("The lefthand endpoint on the X-axis is 0.\n");
      *OK =false;
      while (!(*OK)) {
         printf("Input the righthand endpoint on the X-axis.\n");
         scanf("%lf", FX);
         if (*FX <= 0.0)
            printf("Must be positive number.\n");
         else *OK = true;
      *OK = false;
      while (!(*OK)) {
         printf("Input the maximum value of the time variable T.\n");
         scanf("%lf", FT);
         if (*FT <= 0.0)
         else *OK = true;
      printf("Input the constant alpha.\n");
      scanf("%lf", ALPHA);
      *OK = false;
      while (!(*OK)) {
         printf("Input integer m = number of intervals on X-axis\n");
         printf("and N = number of time intervals - separated by a blank.\n");
         printf("Note that m must be 3 or larger.\n");
         scanf("%d %d", M, N);
         if ((*M <= 2) || (*N <= 0))
            printf("Numbers are not within correct range.\n");
         else *OK = true;
   else {
      printf("The program will end so that the function F can be created.\n");
      *OK = false;
void OUTPUT(double FT, double X, int M1, double *W, double H)
   int I, J, FLAG;
   char NAME[30];
   FILE *OUP;
   printf("Choice of output method:\n");
   printf("1. Output to screen\n");
   printf("2. Output to text file\n");
   printf("Please enter 1 or 2.\n");
   scanf("%d", &FLAG);
   if (FLAG == 2) {
      printf("Input the file name in the form - drive:name.ext\n");
      printf("for example:   A:OUTPUT.DTA\n");
      scanf("%s", NAME);
      OUP = fopen(NAME, "w");
   else OUP = stdout;
   fprintf(OUP, "THIS IS THE BACKWARD-DIFFERENCE METHOD\n\n");
   fprintf(OUP, "  I        X(I)    W(X(I),%12.6e)\n", FT);
   for (I=1; I<=M1; I++) {
      X = I * H;
      fprintf(OUP, "%3d %11.8f    %14.8f\n", I, X, W[I-1]);
   fclose(OUP);
Dear student,
I understand that you are having trouble converting the heat equation backward-difference algorithm in the Burden-faires numerical analysis book into a forward-difference algorithm. I will try my best to help you.
Firstly, let's understand the difference between the backward-difference and forward-difference methods for solving the heat equation. In the backward-difference method, the value of the solution at the next time step is calculated using the values at the current time step, while in the forward-difference method, the value at the next time step is calculated using the values at the previous time step. This means that the backward-difference method is an implicit method, while the forward-difference method is an explicit method.
Now, coming to your question, if you want to convert the heat equation backward-difference algorithm into a forward-difference algorithm, you will need to make some changes in the code. The main difference would be in the calculation of the variable VV, which represents the coefficient of the second derivative in the heat equation. In the backward-difference method, it is calculated as VV = ALPHA * ALPHA * K / ( H * H ), while in the forward-difference method, it would be VV = ALPHA * ALPHA * K / ( H * H ) - 1. This is because in the forward-difference method, we are using the value at the previous time step, so we need to subtract 1 from the coefficient.
I see that you have tried to make this change by writing VV = - [ALPHA * ALPHA * K / ( H * H )], but this is not correct. You just need to subtract 1 from the coefficient, not multiply it by -1. So, the correct code for VV in the forward-difference method would be VV = ALPHA * ALPHA * K / ( H * H ) - 1.
I hope this helps you in converting the code. If you still face any difficulties, please let me know and I will be happy to assist you further.
