Converting mini split AC compressor to 48V brushless motor and controller
magnetic_mike
I want to convert a mini split air conditioner from ac to dc so it can be powered by a 48 volt battery bank and rercharged by a solar panel and wind turbine hybrid system.(hybrid charge controller) I want to replace the ac compressor motor to a 48 volt brushless perminent magnet motor of similar rpm torque size etc. My questions are what about the the circuit board inside? Do I have change anything in there or will it work with the 48 volts from the battery bank? Is the 220 or 120 volt normnal current stepped down for the circuit board and it will step down any voltage input or do I need to make alterations there as well? I haven't tried it yet I am waiting for your expert advice. Thanks in advance. Magnetic_mike
I want to run the air conditioner from a battery bank. Do know how many batteries it takes to get 220 volts? I want a system that is recharged from wind and solar panels. I want the air conditioner to be free from the grid.
what Russ is saying to you, is for you to use a DC to AC inverter, now I don't know of any that have 48V input (there my be?), but there are plenty of 12V and 24V DC input ones with 220V AC output and have wattage ratings of up to 2 - 3kW.
Inverters are pretty efficient these days, 95 - 98%, it would definitely be worth investigating
regardless, you are going to have to consider the wattage required by the aircon and how long any sort of batter bank is going to be able to sustain that power drain before it goes flat. Its is going to require a serious solar panel array to handle the charging required
Dave
