Converting noise into electrical energy
115 replies · 116K views
Hi all,
I have been interested in the conversion of sound into electrical energy as well. I have been reading everyones post about this and how it is seemingly impossible or yet not efficient to convert sound energy into electricity. I am not a physicist but I do study biology and the human ear basically converts sound into electrical signals which are then interpreted by the brain. What I am interested in is understanding how to measure whether this is an energy consuming process (some sort of amplification which I don't think it is) or not. If it is not energy consuming that the largest problem is physically bringing dissipated sound from a large area into a small condensed area where it can create mechanical motion.
The ear takes sound from a large space (via the outer ear) and then propagates that sound through the auditory canal into a smaller more condensed space and causes vibration to the tympanic membrane which causes vibration of the malleus incus and stapes connected to the fluid filled cochlea. Inside the cochlea there are hair like cells... the vibration of the fluid moves these hair like cells (mechanical energy) and that movement is converted into nerve impulse and sent to the brain via the cochlear nerve.
I know this is possible I would really appreciate some help as how to create measurement protocols so I can assess this.
There is an essential difference between detection of signals and using them as a source of energy. The ear, along with all other detection systems (ignore the crystal set), has the job of detecting very low levels of sound signal energy and uses energy from the body to transform this signal into a form that can be used by the brain. The body has to expend energy (from food) to achieve this.
If you want to 'harvest' energy, you can't use amplifiers but you need enough energy for the harvesting system to drive itself and have a worthwhile amount left over. (Otherwise the system is a waste of time and energy). In nearly all circumstances, the flux of sound energy is too low to make harvesting worth while - it would involve deadly levels of sound. If you are talking 'total cost', it is far better to make machinery more efficient so it produces less (wasted) noise energy in the first place. That is a much better engineering solution in most cases.
I guess there may be viable applications for powering very low power devices from available sound energy, because this makes them 'wireless' and they don't need a feed of power from elsewhere. (A bit like the popular solar / wind driven remote systems we are starting to see all over the place.) But the sound levels required are extremely high if you want even just a few miliWatts of usable power. In some cases, you'd find that the total energy put into building the installation could be more than the total energy it can ever supply. It's a possible answer to localised power requirements but we will never 'save the planet' with such sound energy harvesting. (No point in putting one in front of your TV, for instance)
Thanks for the reply. Are you sure that the body's conversion of sound to electric signal is done using energy?
What is the crystal set?
Your reasoning for not harvesting sound: I understand sound in large space is useless but what if sound was culminated from a large area and then transferred into a very small dense area? For example if we accumulate sound from cars made within a tunnel and guided it to a very small area (almost like a funnel) would we be able to create mechanical energy at the smaller end of that funnel? Or do you still think it is far too small of a number?
Oh boy. You must be soooo young!:wink: It was the first type of Radio receiver that enthusiasts used. It consisted of a tuned circuit and a rectifier diode (crystal) with no amplification, that fed a sensitive pair of headphones.
Can you imagine the cost of a suitable funnel, fitted into the side of a tunnel? It would need to have a vast opening and have a long enough taper to match the sound into a suitable transducer. To justify it, you would need actual figures for the likely energy return. How much sound energy flux do you think there is in a tunnel full of cars? You wouldn't get more than that out even if the system were 100% efficient. This is a hard nosed engineering problem which can't be assessed by just arm-waving.
As sound energy is not sufficient for producing large amount of electrical energy
ie.,80db=1milla watt so why don't we go for energy amplifiers having 10^6 gain
One reason may be that energy amplifiers do not exist so far.
An "amplifier" requires a power supply. That power supply would need to provide the extra 99999extra mW. Where would that come from? Answer: the mains electricity supply and not the traffic noise.
When people try to come up with solutions to Engineering problems, they really should apply some of the discipline that Engineering demands. Rule number one: you don't get 'owt for nowt.
Surely we're looking at this from the wrong perspective. When sound is produced this is energy from it's dissipation. We should be thinking about harnessing energy at the point of sound being created. The best place to do this is in looking at waves, and picking up the energy before it dissipates against the rocks and sand.
The best approach is to reduce the amount of noise produced in the first place. It's about making more efficient systems.
Researching on clouds methodology, where i am getting lot of sounds and electricity, this will help me to produce huge amount of sound into electricity.
What constitutes a "huge amount"? 1W, 1MW? If you can't answer that then you have no answer to any of this.
I read that sound absorbing material absorb the sound waves and store it in the form of energy, usually heat. Will it be possible to store this energy through some mechanism over a period of time and then use when there is a requirement?
Why do people ignore the QUANTITIES involved? Is this not the whole crux of this topic? Does the amount of energy involved not strike you as relevant?
nydhruv, Welcome to Physics Forums!
Your suggestion to store heat from the absorption of acoustical energy makes no sense. Did you read sophiecentaur's post(s) above? Do your maths. The AMOUNT or QUANTITY of this heat, if you calculate it, will be tiny, miniscule, infinitesmal, and hardly measurable.
Noise is not a very large amount of energy at all. If a person were to scream as loud as they could for 5 years, they will have produced enough energy in noise to heat a cup of coffee.
http://personal.stevens.edu/~mmohdisa/about.html
Beyond this, there is now a capsule that generates microvoltage from low-frequency sound that powers implanted medical devices.
The tech is new. It will evolve. I envision a transfer process or interface that would further the efficiency of the process. If the SPL can be transferred to a more effective conductor (liquid) I could see it being harvested more expressly.
I keep watching with fascination.
Did you read the conclusions? The Power levels involved are laughable (of course) in the results. Why would you expect that a "more effective conductor" would help? What new principle would it all be based on? They have used their resonators in an attempt to match the impedance of the incoming sound to their energy converter and they have a detectable amount (but so does any microphone) but they do not claim to be getting any more energy than is actually available.
Do you really believe that 'somewhere out there' there is a vast amount of acoustic power? If there were then we would be deafened!
If you go into some cafes, you would have to scream a lot longer than that before you were served?
kthouz said:
Hello everyone!
I have an idea of making a device that can convert noise into electrical energy.
In many fields (industries, cars, construction machines,...), some used machines make much noise, then I thought as sound (noise) causes mechanical energy, why not convert that mechanical into electrical energy as microphones do to convert the sound into electrical signals? But here, i would like that device to be more efficient than a microphone.
So if anyone worked on the same project or knows something about it that can be helpful, please let me know.
Thank you.
I will be posting here what I've done so far.
i want more information relating to this concept so pls most how to start this project
I should read all the posts on this thread before you get too enthusiastic about the idea. You really need to consider just how many mW you might hope to harvest. Some people who have contributed don't seem to be aware of the significance of the actual quantities involved.
hey i also have the same idea but i am confused from where to start and what concept to use. please help me
Google "energy harvesting".
These days it is possible to make things like wireless sensors that power themselves by harvesting energy in various forms (heat, sound, vibration etc). This is mainly because advances in low power electronics allows microprocessors to run on very little power.
Just bear in mind that the law of conservation of energy applies. If you invent a magic box that harvests energy it won't be able to deliver more energy than is available to be harvested.
Just bear in mind that the available energy from sources other than the 'big ones' like sunlight, wind etc., it very very little and there's nothing you can do about that. My grandson has a Science kit which gave him the appropriate metal rods to stick in a couple of oranges and it will just power a small digital clock - and oranges are not free - although someone 'harvested' them.
Think small and you will not be disappointed. Phone charging?? I don't think so, under many circumstances.
isnt it time for this thread to be locked ?
8 pages of round and round in circles
none of these question posters seem to be willing to listen to reality or do the maths and see how pointless the idea is
Dave
