Converting triple integral to spherical
7 replies · 2K views
CINA
Well the best way of checking the limits in a case like this is to draw the regions you are integrating over (ignoring the integrand).
What is the integration region of the first integral?
I'll help you with this one: x goes from 0 to 1, z goes from -sqrt(1-x^2) to sqrt(1+x^2) so these two integrals trace out a semicircle in the x-z plane (in the x>0 region). Since y goes from -sqrt(1-x^2-z^2) to sqrt(1-x^2-z^2) this rotates the semicircle along the y-axis to give a...
What is the second (transformed) integration region?
Are these the same? If so good, if not change the limits so they are.
I don't really get what you are saying.
I know that sqrt(1-x^2-z^2) and -sqrt(1-x^2-z^2) makes a sphere with radius 1, which can be turned into rho=1.
I just can't figure out what phi and theta run to. Since I think it's a sphere (right?) can I assume phi and theta run complete cycles? Is that right?
Can someone please tell me these two limits (and if rho does indeed =1) so that I can see if I'm doing this right?
Wait, if it's a sphere of rho=1, it then projects a shadow on the x-z plane of a circle with radius one, but the only area of interest is from x=0 to x=1.
So a semi-sphere that exists only in the positive-x?
Is that the shape and the correspondingly correct limits?
rho from 0 to 1
phi from 0 to pi
and theta from 0 to pi
Right?
depends on your convention if phi is the angle around the horizontal & the x-axis aligns with phi = pi/2, which i think it does, then yes
