Coordinate transformation into a standard flat metric
The discussion revolves around a coordinate transformation from a metric expressed in terms of variables \(T\) and \(X\) to a standard flat metric in terms of \(t\) and \(x\). The original metric is given as \(ds^2 = -X^2 dT^2 + dX^2\), and participants are exploring methods to achieve this transformation.
  • Participants discuss the use of the chain rule to express differentials and match coefficients in the metric. There is mention of finding transformations through guesswork and checking, as well as exploring the implications of null geodesics in the context of the transformation.
Some participants have made progress in identifying transformations, while others are questioning the clarity and efficiency of their approaches. There is an ongoing exploration of the relationships between the variables and the conditions that must be satisfied for the transformation to hold.
One participant notes that the problem is not an actual homework problem but rather an example from a textbook, which may influence the expectations and approaches taken in the discussion.
offscene
Starting from the metric ##ds^2=-X^2dT^2+dX^2##, using a coordinate transformation of T and X to t and x, convert it to the form ds^2=-dt^2+dx^2 (standard flat 2D metric).
Not actually a homework problem ("confession" from example 7.3 in Hartle's book for Gravity and GR) and no other relevant equations I can think of besides the standard chain rule but thought that this was the most fitting place to ask.
I started by expanding ##dx## and ##dt## using chain rule:
$$dt = \frac{dt}{dX}dX+\frac{dt}{dT}dT$$
$$dx = \frac{dx}{dX}dX+\frac{dx}{dT}dT$$
and then expressing ##ds^2## as such:
$$ds^2 = \left(\left(\frac{dt}{dX}\right)^2+\left(\frac{dt}{dX}\right)^2\right)dX^2+\left(\left(\frac{dt}{dT}\right)^2+\left(\frac{dt}{dT}\right)^2\right)dT^2 + 2\left(\frac{dt}{dX}\frac{dt}{dT}+\frac{dx}{dT}\frac{dx}{dX}\right)$$
But after matching the coefficients to the original ##ds^2##, I am unable to solve the equations to come up with the right transformation and was wondering if anyone could point me in the right direction/show me.
Nevermind, I found the transformation with ##x = X\cosh(T)## and ##t = X\sinh(T)## with some guess and check but is there a cleaner way to do this?
The null geodesics in the usual Minkowski coordinates are given by ##x\pm t = const##. You can find them in the given coordinates and use that to set the coordinate change that matches them. In your case the null curves are given by ##dX^2=X^2dT^2##, which can be solved easily and gives ##Xe^{\pm T} = const## (you don't have to check that these are geodesics, if the change of variables works). So setting ##x+t = Xe^T## and ##x-t = Xe^{-T}## gives you the ones you found.
offscene said:
Homework Statement:: Starting from the metric ##ds^2=-X^2dT^2+dX^2##, using a coordinate transformation of T and X to t and x, convert it to the form ds^2=-dt^2+dx^2 (standard flat 2D metric).
Relevant Equations:: Not actually a homework problem ("confession" from example 7.3 in Hartle's book for Gravity and GR) and no other relevant equations I can think of besides the standard chain rule but thought that this was the most fitting place to ask.
Using the chain rule in [tex]ds^2 = -dt^2 + dx^2 = -X^2 dT^2 + dX^2[/tex] you should find [tex] \begin{split}<br /> \left(\frac{\partial x}{\partial X}\right)^2 - \left(\frac{\partial t}{\partial X}\right)^2 &= 1 \\<br /> \left(\frac{\partial t}{\partial T}\right)^2 - \left(\frac{\partial x}{\partial T}\right)^2 &= X^2 \\<br /> \frac{\partial t}{\partial X}\frac{\partial t}{\partial T} - \frac{\partial x}{\partial T}\frac{\partial x}{\partial X} &= 0\end{split}[/tex] Now the first two equations are satisfied by setting [tex] \begin{split}<br /> \frac{\partial x}{\partial X} = \cosh \zeta \quad \frac{\partial t}{\partial X} &= \sinh \zeta \\<br /> \frac{\partial t}{\partial T} = X\cosh \eta \quad \frac{\partial x}{\partial T} &= X\sinh \eta \end{split}[/tex] due to the identify [itex]\cosh^2 u - \sinh^2 u = 1[/itex]. At present [itex]\eta[/itex] and [itex]\zeta[/itex] are unknown functions of [itex]X[/itex] and [itex]T[/itex], but the third equation gives [tex] X (\sinh \zeta \cosh \eta - \cosh \zeta \sinh \eta) = X \sinh(\zeta - \eta) = 0[/tex] so that [itex]\zeta = \eta[/itex]. The problem is now reduced to finding [itex]\eta[/itex]. We can either find by inspection that [itex]\eta = T[/itex] will work, or we can use equality of mixed partials to find that [tex] \begin{split}<br /> \frac{\partial^2 t}{\partial X\,\partial T} - \frac{\partial^2 t}{\partial T\,\partial X} = <br /> \left(1 - \frac{\partial \eta}{\partial T}\right) \sinh \eta + X\frac{\partial \eta}{\partial X} \cosh \eta &= 0 \\<br /> \frac{\partial^2 x}{\partial X\,\partial T} - \frac{\partial^2 x}{\partial T\,\partial X} = <br /> \left(1 - \frac{\partial \eta}{\partial T}\right) \cosh \eta + X\frac{\partial \eta}{\partial X} \sinh \eta &= 0<br /> \end{split}[/tex] and solving for the partial derivatives we find [tex] 1 - \frac{\partial \eta}{\partial T} = 0 = X\frac{\partial \eta}{\partial X}.[/tex]
  • · Replies 46 ·
