songoku
- 2,515
- 395
- Homework Statement
- Siphon is used to empty tank A. For each statement, check whether it is true or false
(i) At maximum height, the pressure is zero
(ii) According to Bernoulli, for siphon to work well, position of B can be higher than A but must lower than position of water surface at tank.
(iii) Pressure A is equal to pressure B to make the siphon work
(iv) Velocity of water is greater at B than at the maximum height of the siphon
- Relevant Equations
- Bernoulli Equation
Continuity Equation
Hydrostatic Pressure
The answer to this question is statements (i) and (ii) are correct.
(i) I don't understand why this is corect. By "at maximum height", I assume at the highest position of the siphon, but why the pressure is zero?
(ii) I think this is correct because conservation of energy. If B is higher than the water surface, the gravitational potential energy of the water is not enough to push the water through the siphon
(iii) This is wrong because pressure at A is higher than B
(iv) This is wrong because, assuming the siphon has constant area, then by continuity equation the speed at B is the same as speed of water everywhere inside the siphon
Why (i) is correct and are my reasoning for other statements correct?
Thanks
