Correlation between friction force and surface area
Friction force is determined by the normal force and the coefficient of friction, making it theoretically independent of surface area. However, race cars utilize wider tires to increase the contact patch, which enhances grip due to a variable coefficient of friction that can improve at lower loads. The softer, stickier rubber compounds in racing tires require larger contact areas to support the vehicle effectively. Additionally, wider tires can reduce wear rates and overheating, allowing for better performance. Overall, while friction force may not depend on surface area, practical applications in racing demonstrate the benefits of wider tires.
engineer888
As far as I know, friction force is equal to the product of the normal force and coefficient of friction, hence is independent of surface area.
So why is it that race cars have wider tyres than conventional vehicles?
The rubber compound is softer and stickier in racing tires (I'm in North America!), and can't handle the higher internal pressure that a street tire would, so to support the vehicle, you need to have a larger contact patch, and hence wider tires.
Take the surface contact patch area and multiply by the tire pressure to estimate the load it can support. PA = F
Tyre/road friction is extremely complex, there are entire books on just this subject. Your formula is correct for a simple model, however what you may not realize is that the coefficient of friction will not usually be constant, even for the same materials at the same temperature. The coefficient of friction depends on the normal load, usually it is higher for lower loads. So when considering the entire vehicle it is beneficial to have a larger contact area (and a lower pressure between the tyre and road) to increase the coefficient of friction.
There may also be other benefits to wider tyres like reduced wear rates (allows you to use softer rubbers) and less overheating.
What mathematics software should engineering students use? Is it correct that much of the engineering industry relies on MATLAB, making it the tool many graduates will encounter in professional settings? How does SageMath compare? It is a free package that supports both numerical and symbolic computation and can be installed on various platforms. Could it become more widely used because it is freely available? I am an academic who has taught engineering mathematics, and taught the...
  • · Replies 33 ·
  • · Replies 20 ·
  • · Replies 20 ·
  • · Replies 35 ·
