Cosine Rule , what good is it ?
  • Context: High School
  • Thread starter Thread starter junior_J
    Cosine Cosine rule
The discussion centers on the application of the Cosine Rule in vector problems, specifically addressing the confusion surrounding negative lengths. The Cosine Rule, expressed as c² = a² + b² - 2ab cosC, is confirmed to be valid only when using non-negative lengths, as negative lengths do not exist in geometric contexts. Participants emphasize that while vector components can be negative, the lengths used in the Cosine Rule must always be positive, focusing on magnitudes rather than directions.
  • Understanding of the Cosine Rule in trigonometry
  • Basic knowledge of vector quantities and their components
  • Familiarity with geometric concepts of length and magnitude
  • Concept of angles in relation to vector direction
  • Study the application of the Cosine Rule in various geometric problems
  • Learn about vector representation and operations in physics
  • Explore the concept of magnitude versus direction in vector analysis
  • Investigate real-world applications of the Cosine Rule in navigation and physics
Students of mathematics and physics, educators teaching trigonometry, and anyone interested in understanding vector analysis and the application of the Cosine Rule in real-world scenarios.
junior_J
Does the Cosine rule hold true for say negative lengths ? as in a vector quantity like displacement ?
I came across this problem which had -15km and 10km as the known sides whereas the angle opposite the unkown side is 60 degree ...
I tries using c^2 = a^2 + b^2 - 2*a*b cosC but this didnt work ... then on account of frustration i forcibly changed the '-' part of the formula to a '+' only to find that it works ... ?
Can someone explain this to me ??
Mathematics news on Phys.org
ther is no such thing as negative lenght, there is negative coordinates since somepoint has to be 0 and one side will be posetive and the other negative
the 60 degrees is negative, because it is east of north.
negative displacement ? would that apply to the cosine rule ?
There is no such thing as a negative length. A vector quantity (say, in a one-dimensional problem on a number line), or the components of the vector might be negative but the length is always non-negative. If you are using the cosine law in a vector problem, use the lengths, not the components.
so if i had a velocity oh say -15 km/hr ... id use 15 instead of -15 ?? as one of the sides of a triangle ?
yes you would, because you only care about magnitude. The direction comes later.
10K
