Could a Pneumatic Jet-Pack Powered by Pressurized Water Work?
  • Context: Undergrad
  • Thread starter Thread starter bwheeler96
    Calculations Pneumatic
7 replies · 5K views
bwheeler96
I would think someone would have thought about this already, I'm not taking physics so forgive my assumptions about water flow, thrust etc. but, If I were to say... take a 12" I.D. 24" section of PVC Pipe filled about 85% of the way, 6^2*3.14*24/231*.85 = so about 10 gallons, 80 pounds of water for our purposes. The remainder being air pressurized to about 200psi, the water then going through an opening of about 3in^2, for every square inch i should get 200 pounds of thrust to start with, so 600 total right off the bat, and then dropping off rapidly thereafter? Any corrections/comments, would this work?
Forget jetpack, are we talking about a bottle rocket?
russ_watters said:
If you have not yet watched the mythbusters episode on this, please do.
Will do, I understand the jetpack is a "better in theory" idea i just thought that with pneumatics, and i little innovativeness the weight of a jet could be eliminated and a substantial amount of thrust could still be achieved
You mean "jet" as in airliner?
A substantial amount of thrust would provide a lovely boost, but unless you follow that with an amount of thrust required for flight it means nothing. If you don't you're just a glorified bullet.
Amount of thrust required for flight must be > body weight, correct? And from there the more thrust you have, the faster you will accelerate/your top speed will increase? also if 150 p.s.i. of pressure is pushing water through a 3 square inch opening that mean 450 lbs of thrust yes?
Note: I understand that generally we should use kg for this type of thing but I am still getting used to using kg so please work with me here
Assuming we're talking vertical take-off (helicopter style) then yes. For hover, thrust = weight.
Yes
Not necessarily.
Pressure = Force / Area
So Force = Pressure x Area = 150 x 3 = 450lbf. Sounds good to me.
Thanks a ton, I really appreciate all the help. Now how would i go about calculating the rate of water usage? I can't find much on this and I saw a video with too much pressure and not enough water, the guy had plenty of thrust but this did not end well. Any formula for this?
