Could Graphene Become the Next Silicon?
  • Level: Undergrad
  • Thread starter Thread starter sanman
    Graphene Silicon
99 replies · 36K views · last reply
Yes, graphene will probably show up in interconnects before showing up on chips themselves.
The first graphene transistors will be for RF communication.
Then we'll gradually see it showing up in other micro-electronics.
IBM Research has demonstrated an optical link using a graphene photodetector
http://www.eetimes.com/news/latest/...J0MHSBQE1GHPCKH4ATMY32JVN?articleID=224200681
EETimes said:
To achieve the world's first optical data link using graphene, IBM fabricated an asymetrical metal-graphene-metal FET that used palladium and titanium as the source and drain electrodes, respectively, and graphene as the channel. Photons hitting the graphene create electron-hole pairs which would ordinarily recombine in the absence of a strong electric field, but are prevented from doing so by the interdigitated source and drain which intensifies the built-in potential profile of the different metals within the channel.
Regards, Hans
sanman said:
Could graphene achieve superconductivity?
http://physics.aps.org/synopsis-for/10.1103/PhysRevLett.104.136803
Room temperature superconductivity? @ STP conditions?
Now that would truly be amazing!
I don't believe it can, without materials or other science beyond current abilities. Then again, maybe they found some amazing material to dope it with (they mention that in the abstract) and they can make the leap to manfucaturing? The idea of doped carbon as a room temp superconductor that could be reasonably manufactured would be a true leap forward, and one I never expected to see in my lifetime.
That said, Hans' post about a Graphene photodetector almost had me weeping for joy. The more uses that this material can be purposed for, and the easier it is to manufacture, the sooner we'll have it in our computers.
I still think interconnects first as you said sanman... maybe optical links? It might not be a superconductor, but I'd take it! Besides, I'm tired of the occasional computer frying and then getting a whiff of Silane gas... which is truly wretched stuff. :smile:
Quasi freestanding two-dimensional conductor with massless charge carriers
Quasi freestanding two-dimensional conductor with massless charge carriers:
http://www.physorg.com/wire-news/38...imensional-conductor-with-massless-charg.html
translation: there's gold in that graphene!
intercalation of gold atoms between graphene and substrate increases distance between them, to promote electronic decoupling and thus approach the idealized qualities of individual freestanding graphene sheets
New Graphene Fabrication Method Uses Silicon Carbide Template
The new technique has been used to fabricate an array of 10,000
top-gated graphene transistors
http://www.gatech.edu/newsroom/release.html?nid=61435
Regards, Hans
IBM demos 155 GHz Graphene transistor with a 40 nm gate length
http://physicsworld.com/cws/article/news/45649
Some links to previous work of the group:
Feb 5, 2010: 100 GHz with 240nm gate length.
http://physicsworld.com/cws/article/news/41643
Jan 5, 2009: 26 GHz with 150nm gate length.
http://physicsworld.com/cws/article/news/37204
Regards, Hans
I.B.M. Researchers Create High-Speed Graphene Circuits
http://www.nytimes.com/2011/06/10/technology/10chip.html
. . . In the Science paper, the I.B.M. researchers describe a demonstration in which they deposited several layers of graphene on a silicon wafer, then created circuits based on graphene transistors and components known as inductors. They demonstrated frequency mixing up to speeds of 10 gigahertz.
In the past I.B.M. has created stand-alone graphene transistors, but not complete electronic circuits.
Same story at PhysicsWorld
http://physicsworld.com/cws/article/news/46237
