Could Mars Sustain Earth-Like Life with Similar Size and Core?
  • Thread starter Thread starter JeremyPeel
    Mechanics Planet
The discussion revolves around the potential for Mars to sustain Earth-like life if it had similar size and core characteristics to Earth. Participants explore the implications of planetary radius, core composition, magnetic fields, and atmospheric stability in relation to the possibility of life.
  • One participant questions whether Mars would have the same atmosphere and magnetic field if it were the same radius and had a similar core to Earth, expressing uncertainty about how to prove this.
  • Another participant introduces the concept of the Goldilocks Zone as a factor in planetary habitability.
  • A different viewpoint suggests that gravity might limit the potential for life on planets with radii significantly larger or smaller than Earth's, regardless of their distance from the sun.
  • One participant explains their understanding of the Earth's magnetic field, linking it to the solid iron core and molten iron, and inquires about the core size necessary for effective protection against solar winds.
  • Another participant posits that if Mars had similar solid rock content and radioactive elements as Earth, it could maintain a similar magnetic field, while also noting that atmospheric stability is influenced by the composition of gases present.
Participants express various viewpoints on the relationship between planetary characteristics and the potential for life, with no consensus reached on the implications of size, core composition, or atmospheric conditions.
Participants acknowledge the complexity of factors influencing planetary habitability, including magnetic fields, atmospheric composition, and solar radiation, without resolving the uncertainties involved.
JeremyPeel
Please forgive me. My education is lacking go easy on me.
The radius of 6378.1 km has enough gravity to hold this atmosphere in place and has a magnetic field strong enough to protect it.
1. My question is would Mars have the same atmosphere and magnetic field if it were the same radius ((+/- 10% of earth)(not sure how to prove this out)) and had the same radius core ((+/- 10% of earth)(not sure how to prove this out))?
2. Would all bodies with this radius and mass ((+/- 10% of earth)(not sure how to prove this out)) and with enough energy from the parent star have life as we know it?
I think that would imply that the radius of Earth is in direct correlation to life as we know it.
Please let me know if these idea are sound!
Hi Jeremy
welcome to PF
some possibilities there :)
as far as the magnetic field goes, do you understand how the Earth's magnetic field originates ?
also google the Goldilocks Zone to find out about the possibility of planets supporting life as we know it
cheers
Dave
Love the anti-gravity quote btw. Maybe I'm asking the wrong question. Wouldn't gravity prohibit life from any planet with the radius 30 % larger or smaller than earth, regardless of distance from the sun in respect to how gravity holds onto the atmosphere of the planet and all that implies?
I think i understand the magnetic field with the solid iron core and molten iron around that. A big electro-magnet the currents flowing in the churning molten iron correct?
How small would the core have to be to not protect the Earth from the solar winds?
Thanks for all your help. I looked at the links and it was a lot of help.
If Mars had has the similar solid rock content with similar radioactive element amount as earth, that would keep the matle liquid, and that would make a similar magnetic field. I am ignoring local magnetic anomalies generated by solar wind on a planet without significant atmospher, like moon (okey, planetoid)
mass alone does not define atmospheric stability, it has to lack lighter contents, e.g. H, He, and the heavier contents like Earth has to previal for a stable atmosphere. I am also ignoring incoming solar radiation is different in two planets. The incoming solar radiation drives the heating and escape (and some other escape processes) in the atmosphere.
  • · Replies 20 ·
  • · Replies 16 ·
