Could someone me im & desperate
  • Thread starter Thread starter mynameisfunk
    Desperate
11 replies · 2K views
mynameisfunk
could someone please help me I am urgent & desperate
True or False, give proof or counterexample
(1) If [itex]a_n \geq 0[/itex] for all [itex]n[/itex] and [itex]\sum a_n[/itex] converges then [itex]na_n \rightarrow 0[/itex] as [itex]n \rightarrow \infty[/itex].
(2) if [itex]a_n \geq 0[/itex] for all n and [itex]\sum a_n[/itex] converges, then [itex]n(a_n-a_{n-1}) \rightarrrow 0[/itex] as [itex]n \rightarrow \infty[/itex].
I thought i had it solved by setting [itex]a_n[/itex] to [itex]1/(n^2)[/itex]
I don't have much knowledge on infinite series from an analysis point of view. What I have is a limited knowledge from first year engineering calculus so don't take my solution for gold. However, I believe the reasoning is sound. Since you are "desperate" hopefully this will suffice.
[itex]a_n < \frac{\epsilon}{n}[/itex] for every [itex]n > n_0[/itex] since [itex]\epsilon >0[/itex] and the harmonic series diverges.
Thus
[itex]na_n < \epsilon[/itex] for [itex]n > n_0[/itex] . That completes the proof.
The second one is similar since the sequence is cauchy.
EDIT
So both statements are true.
I would think about alternating series.
Isn't a_n >= 0 .
╔(σ_σ)╝ said:
Isn't a_n >= 0 .
True. I missed that. Then think about series with LOTS of zero terms.
Prove the contrapositive. Since [itex]a_n\ge 0[/itex] for all n, so is [itex]na_n[/itex]. If [itex]na_n[/itex] does NOT go to 0, there must be some [itex]a_0> 0[/itex] such that [itex]na_n> a_0[/itex]. That means that [itex]a_n> a_0/n[itex]. But the harmonic series [itex]\sum 1/n[/itex] <b>diverges</b>. That leads to a contradiction.[/itex][/itex]
[itex][itex] <br /> That's not true. n*a_n doesn't have to be bounded away from zero. It just has to "NOT go to 0". Those are two different things.[/itex][/itex]
There is a theorem and states that of a_n does not go to 0 then a_n is eventually bounded away from 0. If not a_n would be in every epsilon neighbourhood of 0. :-$. I am confused !
For part a), it isn't too difficult to prove if the [tex]a_n[/tex] are monotonically decreasing, then [tex]n a_n \rightarrow 0[/tex], so you can prove that a sub-sequence of [tex]n a_n[/tex] converges to 0, but without the monotonicity I don't know...
Right! If a_n=1/n if n is even and a_n=0 if n is odd then n*a_n does not converge to zero. Of course, in this example the series a_n doesn't converge. But it's not hard to fix it so a_n does converge. Put more 0's in! Just making the odd ones zero isn't enough.
Good idea Dick. I've spent too much time trying to prove it correct :redface:
Interesting enough, I had a very similar question (well, part i), not ii) ) in my Analysis midterm that was due Wednesday. I believe I used the Cauchy-Condensation Test for i), and made some argument about na_n being bounded by 2^k a_2^k, and since the latter went to zero, so did na_n.
