Counting U Test for Mann-Whitney Test & Finding Z Value
  • Context: Undergrad
  • Thread starter Thread starter Drudge
    Test
The discussion revolves around the calculation of the U statistic for the Mann-Whitney test and the subsequent determination of the Z value. Participants explore the ranking of data, the application of the U test formula, and the challenges faced in obtaining correct values from their calculations. The conversation includes elements of statistical theory and practical application.
  • One participant describes the process of ranking values and calculating the U statistic using the formula provided, expressing uncertainty about the correct application.
  • Another participant shares a link to a PDF for obtaining a Z-value approximation statistic, suggesting it may help clarify the process.
  • A participant presents a specific dataset and their calculated U value, questioning why their calculation differs from an online calculator's result.
  • Some participants discuss the importance of correctly ranking tied data and how it affects the U calculation, with one participant explaining their method for handling ties.
  • There is a question about the significance of the Z value in relation to the U test and its implications for normal distribution.
Participants express differing views on the correct calculation of the U statistic, particularly regarding the treatment of tied ranks. There is no consensus on the correct approach to obtaining the U value or the Z value, and the discussion remains unresolved.
Participants note potential limitations in their understanding of tied ranks and the lack of clear instructions in their reference materials regarding the calculation of U and Z values.
Readers interested in statistical methods, particularly non-parametric tests like the Mann-Whitney test, may find the discussion relevant, especially those grappling with rank calculations and hypothesis testing.
Drudge
Could some one tell me how to count a U test? I can´t find it anywhere!
So I know you rank the values from smallest to biggest across each sample (if that makes any sense to you) and then you count the ranks together and use the following equation:
U = n(1) * n(2) + ( n(1) * [ n(2) + 1])/2 - R
hope that makes sense. I do not know how to write proper equations. However, it is the samples n multiplied + the samples multiplied (and the other +1) and divided by 2, and finally - R, which is the sum of ranks of x(1) I think.
So then you are supposed to look up on a U-test table and check if U or U(1) is smaller than the critical number, and if so then you rule out Null hypothesis that they are the same.
So I am sure anyone who knows this, knows what I am talking about.
So my question is about how do you get the Z value from this? My book requires it, but does not explain how to. Also online calculators (such as http://www.vassarstats.net/utest.html ) give you the z value.
chiro said:
Hey Drudge.
The table will look something like this:
http://math.usask.ca/~laverty/S245/Tables/wmw.pdf
Take a look at the PDF for obtaining a Z-value approximation statistic.
Ok thank you.
What is U for the following data?
2, 0, 6, 1, 8, 4, 3, 2, 5, 4, 5, 3, 1, 7, 6, 5, 4, 5, 5, 4
7, 8, 3, 6, 6, 7, 3, 4, 3, 5, 8, 6, 9, 2, 4, 5
When I enter these into http://www.vassarstats.net/utest.html I get U(a) to be 214.
Now I understood that U is the sum of ranks - the two n...( as stated in my first post). This way i get 174, when it should be 214, which when put into the z-equation at http://math.usask.ca/~laverty/S245/Tables/wmw.pdf gives the right answer.
why am I not getting the right value to calculate U (and therefore z)?
EDIT: to clarify, I rank all the data, in the same way as the calculator at the above mentioned site,( so they should be correct), then I add up all the ranks together from the first column (data where n = 20) and I get 316, then I use the equation in my first post and get 174, when I should be getting 214 apparently
Just for clarification, are you trying to calculate the median of your data?
I think that is what the U-test tries for, no?
I am studying a statistic book for an exam. There is a problem there as such:
Two groups (<40 & 40<) are measured for the amount of hours they utilize medical services. The results in hours are given respectively in the data I posted last.
Problem: test, do the groups differ with a U test
(answer = U [this means z] = -1,72. This answer you can get from the eqaution you provided in your previous post if you use the U value of 214 of 106 (that is 20(n) * 16(n) - 214).
In my book the only instructions are that you count up the sum of ranks, then you apply the appropriate eqaution and you get U. It does not tell you how to get z however. All well and good though, you can get it when you use the equation that you said, so great.
Why can I not get the right U value? Am I doing something wrong? If you were to count the whole problem from the raw data I gave in my previous post, what would you do different to what I have now explained, and is it something I am doing wrong are what is uP?
If you want to make it easier for the readers, you might want to tell us what the median and then give us the rankings for each of the observations.
Note that a rank for an observation is the number of below-ranked observations that appear before the upper-ranked observations.
I Do not understand
DATA:
RANKS(respectively):
5, 1, 27, 2.5, 34, 14.5, 9, 5, 21, 14.5, 21, 9, 2.5, 31, 27, 21, 14.5, 21, 21, 14.5 (= 316)
31, 34, 9, 27, 27, 31, 9, 14.5, 9, 21, 34, 27, 36, 5, 14.5, 21 (= 350)
[itex]U = 20 * 16 +\frac{20 * (16+1)}{2} -316 = 174[/itex]
For the data point 2 you have 0 and 1 and totaling these gives (0,0,1) which is 3 instead of 2. How have you calculated the ranks?
Gosh, I have no idea what you mean.
I place each row into a column. Then, beginning from the smallest of each column (this case 0) I begin to rank values ( 0 is smallest so it is 1). For tied ranks I add up the ranks, say, in row 1 there was two 1`s so there ranks would be 2 and 3, and 2 + 3/2 is 2.5, so I rank both numbers with 2.5.
Then there are three 2`s, so, ( 4 + 5 + 6 ) / 3 = 5, and therefore I rank each 2 with a 5 and so on...
I might mention that whatever I am doing (wrong) seems to be sufficient enough (according to the answer sheets in my books), when there are no tied data. Since there is no elaboration what to do with tied data in my book, I assume I am missing something that has to do with that, maybe?
By the way, what does the z-value from a U-test indicate? Is it not a normal distribution parameter? what could it have to do with a U-test? To indicate significance?
