Coupled harmonic oscillators QM
The discussion focuses on solving the Hamiltonian for two coupled harmonic oscillators, expressed as H=p1^2/2m + p2^2/2m + 1/2m*omega^2*[x1^2+x2^2+2*lambda*(x1-x2)^2]. Participants emphasize the importance of separating center of mass (CM) and relative motion by introducing new variables: x=x1-x2 and X=(m1x1+m2x2)/(m1+m2). The reduced mass is defined as 1/mu=1/m1+1/m2. The final goal is to manipulate the Hamiltonian to achieve the separation of variables for the eigenfunctions and eigenvalues.
  • Understanding of Hamiltonian mechanics
  • Familiarity with coupled harmonic oscillators
  • Knowledge of center of mass and relative coordinates
  • Concept of reduced mass in two-body systems
  • Study the derivation of eigenfunctions and eigenvalues for coupled oscillators
  • Learn about the application of the reduced mass in quantum mechanics
  • Explore the separation of variables technique in Hamiltonian systems
  • Investigate the role of canonical transformations in classical mechanics
Students and researchers in quantum mechanics, particularly those studying coupled systems, Hamiltonian dynamics, and eigenvalue problems in quantum physics.
valtorEN
Consider two coupled oscillators. The Hamiltonian is given as
H=p1^2/2m + p2^2/2m +1/2m*omega^2*[x1^2+x2^2+2*lambda*(x1-x2)^2]
Separate the center of mass and relative motion and find the eigenfunctions and eigenvalues.
relative coordinate :: x=x1-x2
CM position :: X
i assume that i have to reduce the 2 body to equivalent one body, using the fact that the potential only depends of the separation of the 2 particles x1-x2, that is, if V(x1,x2)=V(x1-x2)
now introduce 2 new variables,
x=x1-x2,
X=m1x1+m2x2/(m1+m2)
now introduce REDUCED MASS 1/mu:=1/m1+1/m2
not sure how to proceed
i guess i put X=x1-x2 into eq above, and t hen try to get into parts for X and reduced mass 1/mu=1/m1+1/m2, so the last term i get is 1/2*m*omega^2[x1^2+x2^2+2*lambda*X^2]
what should i do next?
I'm surprised no one came to help, since the problem's relatively easy.
Just like for the H-atom the separation of the radial and CM motion is done by expressing the particle position and canonical momentum wrt the coordinates and momenta of the CM and the virtual particle.
That is you have to find
p_{1}=p_{1}(X,P,x,p)
p_{2}=p_{2}(X,P,x,p)
x_{1}=x_{1}(X,P,x,p)
x_{2}=x_{2}(X,P,x,p)
and then plug back into the Hamiltonian. You then have to do simple algebraic manipulations which hopefully will lead to the desired separation.
Daniel.
