Crazy dude jumping on a Merry-Go-Round
  • Thread starter Thread starter PhyzicsOfHockey
The problem involves a disk-shaped merry-go-round and a person jumping onto it while both are in motion. The scenario examines the kinetic energy changes in the system, including the rotational motion of the merry-go-round and the linear motion of the person.
  • Participants discuss the initial and final kinetic energies of the system, questioning whether the kinetic energy increases, decreases, or remains the same when the person jumps onto the merry-go-round.
  • Some participants explore the conservation of momentum and the relationship between the tangential speeds of the person and the merry-go-round.
  • There are attempts to calculate the initial and final kinetic energies, with some participants expressing uncertainty about their calculations and the inclusion of the person's kinetic energy prior to jumping.
The discussion is ongoing, with participants providing insights into the kinetic energy calculations and the implications of the person's speed relative to the merry-go-round. Some guidance has been offered regarding the conservation of momentum and the need to consider both the person and the merry-go-round in the system.
Participants are navigating the complexities of rotational dynamics and kinetic energy, with some expressing confusion over the definitions of the system and the calculations involved. There is an acknowledgment of the need to account for the moment of inertia changes when the person jumps onto the merry-go-round.
PhyzicsOfHockey
A disk-shaped merry-go-round of radius 2.63 m and mass 155 kg rotates freely with an angular speed of 0.686 rev/s. A 59.4 kg person running tangential to the rim of the merry-go-round at 3.99 m/s jumps onto its rim and holds on. Before jumping on the merry-go-round, the person was moving in the same direction as the merry-go-round's rim.
(a) Does the kinetic energy of the system increase, decrease, or stay the same when the person jumps on the merry-go-round?
increase
stay the same
decrease
(b) Calculate the initial and final kinetic energies for this system.
Ki = kJ
Kf = kJ
KErot= 1/2*Iw^2
I=1/2mr^2
a) I would think it should increase but I am probably wrong, lol.
b) The merry-go-round initially is just spinning so I trued finding the KE using the 1/2*I*w^2 formula so I got 1/4*m*r^2*w^2and I came up with 4.98 kJ and that's the wrong answer... is there something I did wrong?
I don't have any idea how to find the KEf. Can I assume that its the rotational KE of the merry-goround plus the KE of the guy jumping on it?
Lets start with the initial KE. You have a rotating disc included in your system; is there anything else that has KE?
Try comparing the rim's tangential speed (where the person jumps on) with the speed of the individual, and keep in mind, when the person jumps on, they must have the 'same' tangential speed.
If the person is traveling faster, the person slows down, but the merry-go-round must increase its rev/s.
No the disk is the only thing that has KE? Maybe there is something I am just not understanding about this disk.
Sorry, maybe I do not understand what your system is?
The person is running.
the edge of the merry go round is moving at 11.336 m/s much fast then the man. So the merry-go-round slows down. I did conservation of momentum.
Initally...
Lmgr= I*w= 2310.58
Lp=I*(v/r)=623.326
Ltot= 2933.9
using this I found the angular speed of the merry-go-round fonal
2933.9/(Imgr + Ip)=w=3.09832 rad/sec
But I can not see how this helps me find the initial or final conditions.
So I must include the guy running although he's not on the merry-go-round yet?
So I did KEi= .5*Imgr*Wmgr^2 + .5*Ip*Wp^2 and got 5.4524 kJ
then i did KEf= .5*(M1+M2)*r^2*.5*Wf^2 and got 3.559kJ
Am I even close?
I guess I am not because that's still the wrong answer
Robb has given the answer.
The initial KE = KE ( disc) + KE (man)
Final KE = initial KE = KE(disc)
Remember that when the man steps on the rim, he increases the MoI of the roundabout by m*r^2.
True Mentz144 but the Final KE does not equal the Initial KE. I finally figured it out. my KEi was right but I added masses when finding the new MoI not m*r^2 to the MoI of the disk.
Phyz, The question asks is energy being lost or gained by the >>system<< during the process. Taking the man and turntable together as the system, I venture that the energy is the same before and after.
Energy is being lost because energy is required to make the mans speed the same speed as the merry-go-round. But thank you for your input.
  • · Replies 44 ·
