Crazy water pressure formula implication?
The forum discussion centers on the implications of water pressure in a hypothetical tank the size of the Pacific Ocean, connected by a narrow chimney. The formula for water pressure, defined as (Water density) * (Acceleration of gravity) * (Depth of object underwater), suggests that adding a small amount of water can create significant pressure throughout the tank. Participants clarify that pressure is transmitted equally in all directions, but the actual pressure at any point depends on the height of the water column above it. The conversation also touches on the speed of pressure wave propagation in fluids, which is determined by the fluid's properties.
  • Understanding of hydrostatic pressure principles
  • Familiarity with fluid dynamics concepts
  • Knowledge of pressure wave propagation in fluids
  • Basic grasp of molecular interactions in liquids
  • Study the hydrostatic pressure formula and its applications in fluid mechanics
  • Explore the concept of pressure wave speed in different fluids
  • Investigate the effects of surface tension and capillary action in narrow tubes
  • Learn about molecular dynamics simulations to visualize pressure distribution in fluids
Physics students, engineers, and anyone interested in fluid mechanics and hydrostatics will benefit from this discussion, particularly those exploring the implications of pressure in large bodies of water.
  • #31
Dadface said:
I thought the question has already been answered or am I missing something here?You can and do get pressure fluctuations at a particular point in a liquid due to,as another example,surface variations such as waves.These fluctuations tend to cause a flow within the liquid and the pressure becomes equal at each point at the same horizontal level within the liquid but only when and if an equilibrium is reached,the surface becoming level.
In the OP, if I'm not mistaken, he is referring to fluid in a tank, hence this a fluid statics problem and any dynamic effects are to be neglected.
CS
  • #32
http://www.ac.wwu.edu/~vawter/PhysicsNet/Topics/Pressure/HydroStatic.html
Go to this part it is a near match for the image described in the original question
Vessel C: Again we could divide the water into three sections. The middle section is similar to that of vessel A or B. Since the height of the fluid in section 1 or 3 is not high enough to produce the same pressure as the height of the fluid in 2, how does the pressure on the bottoms of section 1 and 3 get to be the same as that of 2 ?
The answer is that top of the container's walls in sections 1 and 3 produce a downward pressure that is equal to the fluid pressure in the middle section at the same level. If you poked a hole in the top of the container in sections 1 or 3, water would fountain upwards from the hole under pressure. From Pascal's principle, this pressure has to be that of the fluid in the middle section at the same level.
kotreny said:
Hey everyone, I just thought of a mind-boggling "thought experiment":
As a reminder, the formula for water pressure acting on an object due to weight is:
(Water density)*(Acceleration of gravity)*(Depth of object underwater)
Note that the shape of the container doesn't matter.
Imagine a water-filled tank the size of the Pacific Ocean (exact measurements won't be necessary). The tank is completely filled with water and is sealed shut, so any pressure other than water pressure is absent. Now imagine that at one corner of the tank there is an incredibly narrow "chimney" about ten nanometers in diameter and extending about ten kilometers above the top of the tank. This tube is connected directly to the big tank and is sealed shut, though the water level can be changed at will. I didn't do the math, but I'm pretty sure a few drops of water would raise the water level by at least hundreds of meters.
The weird part: According to the formula, water pressure throughout a container is dependent only upon the height of the container, assuming gravity and density remain constant. Technically, our imaginary tank is over ten kilometers tall, since the chimney is part of the tank. Does this mean that adding just a few drops of water can create enormous pressure everywhere in the ocean-sized tank? Seems to violate the law of conservation of energy, doesn't it?
Yes, I know that pressure is force/area, so the weight of the drops is concentrated like a needle. But can anyone tell me how--preferably on a molecular level--that force is distributed to every part of a body of water as big as the PACIFIC OCEAN?
Thanks
OK now he presents the problem that using the formula it gives a MASSIVE amount of pressure.
I said right off that the pressure would be spread out evenly if you dissagree with that point say so.
And if you do dissagree go look at the web link above.
If you use only that one formula it does not apply to the process of the pressure distribution it ONLY applies to the pressure at the bottom of the column.
We are dealing with columns of 2 different heights not just 1
  • #33
No, that one formula works everywhere, not just at the bottom of the column of fluid.
However, the height (at any point) is measured from the fluid surface (i.e. the total height to that point whether at the bottom or not). Take a look at the very last picture on that website...it shows why it is only pgh and nothing more...if you still don't get it...look at it again and again until you do...or take a fluid mechanics class.
In the OP, it was asked whether or not a few drops in a tube would cause the tank level to raise. Well, technically it would, but it would be essentially infinitesimal due to the vast volume of the tank (assumed to be the size of the ocean). He then stated that according to the theory, pgh, it would raise the ocean by hundreds of meters. He stated that because he didn't understand at the time the relationship between hydrostatic pressure and depth.
The tank would not be raised hundreds of meters, the volume of the drop of fluid would be spread through out the tank, there by resulting in a very very small pressure increase (i.e. the total tank height would not increase but a very very small amount which results in the very very small pressure increase AT ANY POINT IN THE TANK).
Again, the pressure is only a function of pgh in a static fluid such as the one described.
CS
  • #34
actually he is saying that it is a full tank and a few drops are added to fill the column otherwise why make the column so high.
So stated again could only a few drops of water ACTUALLY increase the pressure by such a massive amount or is the formula perhaps flawed in applications of this extreme type of scenario.
Not every formula works for every situation, perhaps this could be an exception.
If there were a submarine floating in that tank the formula rho*g*h would cause that sub to be crushed by a few drops of water. Can you be sure that it would happen is there no doubt whatsoever.
  • #35
TheInversZero said:
aSo stated again could only a few drops of water ACTUALLY increase the pressure by such a massive amount or is the formula perhaps flawed in applications of this extreme type of scenario.
If you ignore the real world effects of surface tnesion and intra-molecular forces it does
The single atom underneath that narrow column of water could be 'crushed'
Think of a knife blade. You can hold a 1kg brick in you hand safely because the force is spread out over the size of brick, but the weight of a 20g scalpel would push the blade through your finger. A really sharp edge like a microtome blade, only 1 atom across, would exert an enormous pressure which is why it able to slice through materials with almost no force.
  • #36
if you want a really weird and counterintuitive result of water pressure - image a dry dock.
You have a 50,000ton battleship in a dry dock and let water in so that it floats.
Now imagine you had made the dry dock smaller - only about the same length and width as the boat, you would need less water but it would still float.
Now imagine you made a dry dock that was perfectly the size and shape of the boat - so that there was only a microscopic gap between the hull and the dock. Then you could put a teaspoon of water in the gap and the boat would float.
  • #37
If the tank is completely full and sealed with only a tube sticking out of the top, and water is added in the tube, then yes the pressure will increase and be equal to pgh, where h is the total height from the top of the fluid level in the tube to whatever point you are interested in. I'm 100% sure that is true, without a doubt.
Note that this is not the same case as dealing with an ocean...the ocean is open to atmosphere and will have room to rise whereas a sealed and completely full tank does not have room to rise. If the tank has room to rise, then the volume of water is spread out as stated before and the pressure increase is negligible.
If a submarine was in the tank as described, then adding a fluid column with a height of 10 km would certainly crush it.
There is no exception to this formula. It works for all cases.
CS
  • #38
<snip>
Thanks
I haven't seen anyone mention this, but even though the pressure (and force applied to the container) will indeed grow very large, because of the conservation of energy the (virtual) displacement of pacific ocean against the container will be proportional to the area of the column. So as the column diameter shrinks, the container walls will only need to move a vanishingly small amount to compensate.
Put another way, as the container begins to bulge, the water in the column drops, reliving the applied pressure.
  • #39
I think the OP assumed a perfectly rigid container in their thought experiment.
CS
  • #40
OK thank you for all the consrtuctive results of this thread.
New thread just not officially started yet.
Given the formula rho*g*h
A tube extending to space with a small diameter. What possible "not practical" applications could there be to launching a satellite into space using the massive pressure of water.
This is more theory then anything else.
Perhaps try including other potential applications of this.
Have fun let your minds wander.
  • #41
Mind wandering...getting nowhere.
Huh?
  • #42
Some wording issues make me wonder if there isn't just a misunderstanding (doubt it) about what some are saying. I'm not sure what "spreading out" is supposed to mean. So I'll refer you back to the challenge and example I gave waaaay back in post #22:
As a hypothetical, consider a 1 meter cubed tank with a 1 square centimeter column of 1m height sticking out the top. Calculate for me the pressure at the top of the tank and provide a reference for your method of doing the calculation.
Consider also a real example I work on every day: the heating water piping system in a building. How would you go about calculating the static head pressure at the bottom of the system? I use p=rho*g*h and it works.
No one has answered it, so I'll just give the answer (and a few more).
1. What is the pressure everywhere along the bottom of a 1 meter cubed, open water tank? Answer: 9800 n/m^2 (.097 atm)
2. If you put a top on the tank, install a 1m tall open pipe of 1 sq cm cross sectional area on top and fill it with water, what is the pressure at the bottom of the pipe? Along the entire top surface of the tank? Answer: 9800 n/m^2 (.097 atm). What is the pressure along the entire bottom surface of the tank? Answer 19600 n/m^2 (.194 atm).
If you have a 100m tall building with a hot water heating system in it, vented at the top, what is the pressure at the suction side of the pump in the basement with the pump off? Answer: 980,000 n/m^2 (9.7 atm)
Agree or disagree?
  • #43
You are very right Russ pressure is a value of, Newtons divided by Meters squared. N/Msquared
I am trying to figure out how many square meters are at the base of a nano tube. Perhaps you could enlighten us.
  • #44
But as soon as the submarine began to deform the level in the tube would fall and the pressure relieved, then you would have to refill the tube, little more deformation, by the time you had filled the tube often enough to destroy the submarine you would have used as much energy lifting the water to the top as you would have blowing the thing apart.
If you want an analogy think of a Van de Graaff generator lots and lots of volts but bugger all power.
  • #45
Why would you care? It's irrelevant to the problem. p=mgh <-where do you see area in that equation?
  • #46
Pressure at the bottom of the mile high tube will be incredibly high. Pressure in the ocean will remain unchanged. And then the water in the tube will fall to the level of the ocean, and the pressure in the tube will drop to that of the ocean. Pressure in the ocean wills still remain unchanged.
13K
  • · Replies 72 ·
  • · Replies 23 ·
