Critical angle/ last angle of refraction
The critical angle for a piece of glass with an index of refraction of 1.45 is calculated to be 43.6 degrees using Snell's Law. The discussion highlights the ambiguity in the problem regarding the incident angle of the light ray and the slope of the glass, which complicates the drawing of the light path. Participants suggest assuming the light enters normally at 90 degrees and the slope is 45 degrees, leading to multiple reflections within the glass before exiting. The lack of clear parameters in the homework question is noted as a significant challenge.
  • Understanding of Snell's Law and its application in optics
  • Knowledge of the concept of critical angle in refraction
  • Familiarity with light ray diagrams and their construction
  • Basic principles of geometric optics
  • Study the derivation and applications of Snell's Law in various media
  • Learn about total internal reflection and its conditions
  • Explore advanced ray tracing techniques for optical systems
  • Investigate the effects of varying incident angles on light behavior in different materials
Students studying optics, physics educators, and anyone involved in optical design or analysis of light behavior in materials.
davidelete
A piece of glass has the shape shown in the below diagram. The index of refraction of the glass is 1.45. Find the critical angle for the glass. Sketch the path of the light ray until it emerges from the side of the figure and find the last angle of refraction.
http://img179.imageshack.us/img179/6531/physicsimageez8.png
Sorry if the image is a little ugly...
Snell's law
n_1\sin\theta_1 = n_2\sin\theta_2\ .
sin-1(\frac{1}{1.45})=43.6 degrees.
I have no idea on how to draw in the diagram. Could someone help me on drawing it? Mine just looks like a bunch of rays bouncing around inside an irregular pentagon on my paper when I try it.
Are we told the angle at which the light is incident on the glass? Is it incident normally (at 90 degrees)?
That is truly everything. I would just have to assume 90 degrees based on the information given.
I don't understand how you're expected to solve that without the incident angle and also the angle at which the glass is sloped on the left hand side.
I suppose it is more of a best guess type of thing. What would your best guess be when drawing a light beam coming in? Where would it bounce to? Where would it exit?
If you don't know what angle its entering the medium relative to the normal then how are you supposed to know if it will internally reflect? It could either exit the medium on the second face or bounce around inside for a while...
As a best guess, and this seems so entirely unphysical that it should have a disclaimer, i'd assume it enters the medium normally, and assume that the angle of the slope is 45 degrees. Since this is a larger angle than critical, it's going to bounce off the lower face, then off the top face, then off the right face, then off the bottom face, and then exit normally out the face it came in through.
Thank you. That was exactly what my best guess looked like as well. Some of the questions on these homeworks are outrageous. I wish they gave more information.
