Cubic graph containing a 1-factor
  • Thread starter Thread starter Robb
    Cubic Graph
A 1-factor, or perfect matching, in a graph is a 1-regular sub-graph where every vertex is matched with exactly one other vertex. To determine the existence of a 1-factor, one can use the condition that for a graph G with vertex set S, the number of components after removing bridges must satisfy k_o(G-S) ≤ |S|. A bridgeless cubic graph will always contain a 1-factor, as will cubic graphs with at most two bridges. The discussion also includes a construction method involving three pentagonal circuits and a triangle to illustrate a cubic graph with three bridges. Understanding these concepts is crucial for analyzing cubic graphs and their factors.
Robb
Does there exist a cubic graph with three bridges that contains a 1-factor?
##k_0 (G-S) \leq |S|##
I understand how to show a given graph does/does not contain a 1-factor but I'm not sure how to show existence (or the lack thereof). Please advise.
Please define 'factor' here. I am familiar with the concept of Bridges but not with the concept of factors. And maybe you can add tags at the end of your expression so the Latex can render?
1-factor is the same as a perfect matching-A graph G has a perfect matching iff for ##S \in V(G), k_o(G-S) \leq |S|##. If G has odd order, then G has no 1-factor. A 1-factor is a 1-regular sub-graph of G.
Also, every bridgeless cubic graph contains a 1-factor as well as every cubic graph with at most two bridges contains a 1-factor.
Likes WWGD
Restrict attention to a connected graph. If you remove the bridges the graph will fall into a number of components. What can you say about the number of vertices in each?
Since the thread seems to have died, here's my solution.
Start with three pentagonal circuits and a triangle.
Connect each vertex of the triangle to a vertex of a pentagon to make the graph connected with three bridges.
Within each pentagon, connect the remaining four vertices as two pairs, making the graph cubic.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
