Cumulative distribution problem Statistics
19 replies · 3K views
stats_student
Let X be a continuous random variable with cumulative distribution function given by F(x) = P(X<x).
Define a new random variable U=F(X).
OK so to solve this problem I first say U=F(X).
F(u)=P(F(X)<u)
which means
F(u)=P(U<u)
is this how i should solve this problem?
You haven't stated what question is being asked of you.
Also, you will need to use more careful notation to avoid getting confused between the cdf of X and the cdf of U.
I suggest using a subscript, so that ##F_U## is the cdf of U, ie ##F_U(u)=Pr(U<u)##.
F(u)=P(U<u)
which means
F(u)=P(F(X)<u)
ignore that top post mis clicked.
However the questions asks to find the supports of U and the median.
I'm a little confused how to approach but can i say that u<x?
If that's not the case can you point me in the right direction.
Thanks
Well, start with the support. What are the maximum and minimum possible values for F(X)? The support of U will be the interval between those.
By the way, there's a big hint in the choice of the variable name U. Can you think of a simple distribution whose name starts with the letter U?
the possible values for F(X) is negative infinity to infinity.
Uniform distribution?
Also would i be able to say that U ranges from negative infinity to infinity also?
F(X) is a probability. What is the range of possible values for a probability?
What is the range of possible values for a random variable whose distribution is the standard uniform distribution? How does that compare to the range of F(X)?
oh i see, so F(X) the range would be 0 to 1.
the range of values for a random variable whose distribution is the standard uniform distribution is negative infinity to infinity.
not should what you mean when you say compare the two?
The range of possible values for a standard uniform random variable is the real interval [0,1]. If you've never come across standard uniform random variables before then it won't help you to realize that U is one, so perhaps don't worry about that side of it. Go back to your equation:
$$F_U(u)=Pr(F_X(X)<u)$$
Now since ##F_X## is a monotonic increasing function, you can invert it. What happens if you apply ##{F_X}^{-1}## to both sides of the inequality inside the parentheses?
After that you'll have one more step, which involves using the fact that ##Pr(X<x)=F_X(x)##.
ok so would it be correct to say that U=F(X)
then the support of this must be U[0,1]
and thus the median will be 1/2
and the 25th percentile would be 1/4 and the third percentile would be 3/4?
You tell us.
well because U is essentially the height of the function and F(X) can only be between 0 and 1. then it must be so that the height U must be equal to [0,1]? is that sound reasoning?
or should i say that because F(U) ranges from 0 to 1 then u must range from 0 to 1?
stats_student said:
anyone?
Always start with a picture; it will help you straighten out your thinking. Look at the correspondence between ##X = x_0## and ##U = u_0 = F(x_0)##:
