Current and Voltage values using Ohm's Law
1 reply · 3K views · last reply
Kas0988
Circuit schematic: voltage source Vg in the left branch, series resistor R1 with current i1 flowing right, then R2 and R3 in parallel across the node, with V2 across R2 and V3 across R3, currents i2 and i3 marked.
In the circuit above given that Vg is 55 V, R1 is 3 Ohm, R2 is 12 Ohm and R3 is 90 Ohm. Using the polarity shown in figure answer the following questions.
(A) Find the value of i3?
(B) What is the value of i2?
(C) What is the value of V3?
(D) Calculate the power dissipated in R1?
(E) Calculate the power delivered by the source Vg?
Ohm's Law (I = V/R)
Parallel Resistance Formula (R1 + R2*R3/R2+R3)
I was able to configure the Parallel Resistance Formula correctly (I think) using the figure drawn with this problem. After that, I did the following:
Total V = 55 V (Vg... Given)
Total R = R1 + R2*R3/R2+R3 = 1083/102 = 10.62 Ohm (Formula Above)
Initial I = V/R = 55/10.62 = 5.18 A (Or I1)
then V=(I1)*(R1) across the first resistor to find V at the node = 15.54 V
I2 = that V/R2
I3 = I1-I2
and V3 = I3R3
And so forth. My I2, however, is not showing up as the right answer. I feel like I am either missing a step, or did not setup the resistance formula correctly. Help?
Welcome to PF!
Hi Kas0988! Welcome to PF! :smile:
(try using the X2 tag just above the Reply box :wink:)
erm :redface: …
you've added the 3 in the wrong place! :cry:​
