Current flowing in a branch in a circuit
13 replies · 2K views
Jahnavi
For calculation sake I will consider R = 1Ω . Final answer will be in mA instead of A .
The middle two resistors 3R and 4R are in parallel , so I consider their equivalent resistance 12R/7 in the middle branch .
In the left part of the circuit , suppose i1 current flows in R .
In the right part of the circuit , suppose i2 current flows in 2R .
Current flowing in the middle 12R/7 resistor will be i
Using KCL i = (i1+i2)
Writing KVL in the left loop ,
12 - i1 - 12i/7 = 0
Writing KVL in the right loop ,
24 - 2i2- 12i/7 = 0
Solving for i , i = 6.72
This is the sum of the currents that will flow in the middle 3R and 4R resistors .Since they are in parallel , current will be divided in the ratio 4:3 .This means (1/7)th of the current i =6.72 flows in the middle lower branch ( the one that is asked in the question )
This gives 0.96 which is incorrect .
What is the mistake ?
I believe node voltage method is an easier way to do this. Call the middle node voltage V and write KCL at that node. Assume the negatives of the batteries to be the ground node.
I will do as you suggest . But for now , please help me identify the mistake in the OP .
How? I see you have assumed I=I-I.
Is that correct?
Is that correct?
No .
It should be (4/7)i - i1 . But this gives 3.36
I tried your approach . This also gives 3.36 :wideeyed: .
Jahnavi said:
I tried your approach . This also gives 3.36 A .
Right. I get the same answer.
Jahnavi said:
No .
The same as I got.
Is it only me who is not able to see 3.36mA in any of the given options o0) ?
It's not the first time that the options are incorrect.:wink:
By the way , I agree that your approach is much simpler :smile: and most probably the paper setter expects us to apply the Node Voltage method .
This is quite helpful . What if the polarity of one of the batteries is reversed ?
Do you still think that node voltage method will still be more efficient and simpler considering that now there will be two equations to deal with ?
Jahnavi said:
Do you still think that node voltage method will be still more efficient and simpler considering that now there will be two equations to deal with ?
Yes. No matter what the polarities are, there are still only 4 nodes, one of which is the ground node and you know two node voltages. So you end up with a single equation with a single variable.
In general, you can assume any node to be the ground node. As long as you are consistent with signs in KCL, you are fine.
