Why Does Electron Movement in a Neutral Wire Not Affect Its Overall Charge?
  • Context: High School
  • Thread starter Thread starter member 529879
    Current Wire
The discussion centers around the question of why a neutral wire remains neutral when electrons within it begin to move. Participants explore concepts related to charge distribution, electron behavior, and relativistic effects, touching on both theoretical and conceptual aspects of electromagnetism.
  • Some participants question the assumption that moving electrons would lead to a net negative charge in the wire, suggesting that if electrons leave the wire as others enter, the wire remains neutral.
  • Others argue that the electric fields of electrons may undergo contraction, but this is not straightforward and involves transformations that lead to magnetic fields in the wire's frame.
  • A participant mentions that electrons in a conductor do not travel at relativistic speeds, and that the wave action propagates changes quickly, akin to marbles in a tube.
  • There is a discussion about how distances between particles may contract from different reference frames, but this does not necessarily imply a change in overall charge of the wire.
  • One participant asserts that the wire can become positively or negatively charged based on the overall voltage applied, rather than length contraction affecting charge directly.
  • Some participants express confusion over the implications of length contraction and its relevance to the charge of the wire, indicating a need for clarity in understanding these concepts.
Participants express differing views on the relationship between electron movement, length contraction, and charge neutrality in the wire. There is no consensus on how these factors interact, and the discussion remains unresolved regarding the implications of relativistic effects on charge distribution.
Limitations in understanding arise from the complexity of relativistic transformations and their effects on electric and magnetic fields. The discussion highlights the need for careful consideration of reference frames and the behavior of charges under different conditions.
member 529879
If a wire is neutral, and the electrons in it suddenly start to move, why is the wire still neutral? I would think that the electrons would contract causing the wire to be negatively charged.
Why do you think the electrons would contract? Electrons, as far as we can measure, are point sources so how could they contract? If when current starts to flow, as many electrons leave the wire as are added to it, why would it not still be neutral?
Electrons do not travel at relativistic speeds in a conductor. In fact they travel quite slowly. It is only the wave action that travels at the speed of light. The popular analogy is marbles packed in a tube. The marbles may be traveling very slowly in the tube but any change in motion moves from the input to the output very fast.
The electric fields of the electrons do sort of "length contract", but they don't do so in a simple way like you are thinking. The static electric field in the rest frame of the electrons is transformed by a Lorentz transformation, partly into a magnetic field in the rest frame of the wire.
See here for some details: http://en.wikipedia.org/wiki/Classical_electromagnetism_and_special_relativity
But there are a lot of electrons and protons in a wire, so contracting of particles in the wire cause it to repel or contract moving charges.
Particles themselves do not contract, the distances between protons do, as viewed in the frame of the moving electrons. The distances between the electrons contract, as viewed in the frame of the wire. Like I said, after everything is considered, this leads to a magnetic field being present in the frame of the wire, and will, in fact, give you Ampere's law. Because the transformed field is a magnetic field, the consequences are not so simple as they "attract or repel" other charges.
Notice in your video that the cat has to be moving in order to feel some forces. This is a direct consequence of the fact that magnetic fields don't work on static charges, but only on moving charges via the Lorentz force.
All in all the video doesn't say much but what Maxwell's equations state, just from the prespective of a simplified Special Relativity point of view, where electricism and magnetism are just one force, seen from different reference frames.
As he states, although in his reference frame there is no "free" charge in the wire, he is seeing the charged cat moving because of the magnetic field. On the other hand the cat is not experiencing a magnetic field but an electric field because it's moving.
The maxwell equations except for charges as sources of the electric field, also have the change of the magnetic field. In SR both them are unified into one quantity - the EM antisymmetric tensor.
PS personally I don't like the contraction example...it caused me a mind explosion right now...
That would make the wire negatively charged, in the wire frame.
... So the distances between the electrons stay constant in the wire frame, when the current is adjusted.
Yes, you are right. I got too sloppy in carrying out the relativistic corrections in my head. The distances between the electrons stay constant, they are just drifting along. In fact, the video mentions this as well. :)
On the positive side of the wire it becomes a little positively charged. On the negative side of the wire it becomes a little negatively charged. So the net charge is 0.
If you want it to be positively charged you can just raise the overall voltage. If you want it to be negatively charged you just lower the overall voltage.
Length contraction is irrelevant. The charge is determined by the voltage. This isn't to say that length contraction doesn't happen, it does and it can be used to understand magnetism. But it doesn't control the charge on the wire.
  • · Replies 20 ·
  • · Replies 36 ·
  • · Replies 20 ·
