What is the current induced in a wire loop placed in a changing magnetic field?
A closed square wire loop with a side of 4 cm is placed in a perpendicular, increasing magnetic field at a rate of 0.3 T/s. The resistance of the loop is 2 x 10^-3 Ω, leading to an induced electromotive force (E) calculated using Faraday's law of induction. The correct induced voltage is found to be -4.8 x 10^-4 V, resulting in an induced current of 0.24 A. The discussion highlights the importance of using the appropriate formulas for calculating induced current in changing magnetic fields. Understanding the relationship between induced current direction and magnetic field direction is also emphasized.
moenste
A closed wire loop in the form of a square of side 4 cm is placed with its plane perpendicular to a uniform magnetic field, which is increasing at the rate of 0.3 T s-1. The loop has negligible inductance, and a resistance of 2 * 10-3 Ω. Calculate the current induced in the loop, and explain with the aid of a clear diagram the relation between the diraction of the induced current and the direction of the magnetic field.
Answer: 0.24 A.
2. The attempt at a solution
Well, I used the E = B L v and I = V / R formulas.
E = 0.3 * (4 / 100) = 0.012 V.
I = 0.012 / (2 * 10-3) = 6 A.
What's wrong here?
Hi!
Here's a hint -
moenste said:
E = B L v
Does this formula seem to apply here? Could you please list the value of each of these variables?
Likes moenste
LemmeThink said:
Hi!
Here's a hint -
Hi!
E = voltage, B = magnetic field, L = length, v = velocity.
If know that this formula is not the best fit for this problem (we don't know velocity). But which one do you suggest?
Do you know Faraday's law of induction?
Likes moenste
Got it from here. Thank you!
E = - N (d Φ / d t)
d Φ / d t = 0.3 T s-1 * A, where A = (4 / 100) * (4 / 100) = 1.6 * 10-3 m2.
E= - 1 * 0.3 * 1.6 * 10-3 = - 4.8 * 10-4 V.
I = V / R = 4.8 * 10-4 / 2 * 10-3 = 0.24 A.
Likes LemmeThink
  • · Replies 0 ·
