Curved Space-time and Relative Velocity
331 replies · 52K views
Let's stick to inertial frames. If you are going to be using non-inertial frames then the usual process that we already covered in great depth applies. If you use non-inertial frames then you are simply doing standard parallel transport and there is no conceptual difference between one non-inertial coordinate system and another.
Anamitra said:
1)We take a chain of inertial frames from A to B along L1 wrt orthogonal bases whose axes are parallel to each other individually. This may be achieved by parallel transport of the axes.The basis at B is slided down to A by parallel transport to A along L2.
i) When a vector T[[tex]T^{0},T^{1}T^{2}T^{3}[/tex] ] moves from A to B along L1 the components do not change.
ii) The two bases at A ate not identical. The same vector will have different components in the two bases at A.let A1 be the basis wrt L1 and A2 the basis wrt L2.
Yes, exactly.
Anamitra said:
4)Let the components of the tensor T at A be [tex]T^{0},T^{1}T^{2}T^{3}[/tex] in the basis A1 and [tex]T^{'0},T^{'1}T^{'2}T^{'3}[/tex] in the other[A2].WE choose a transformation in such a way that when we move from A to B along L2 the tensor at P has the components [tex]T^{0},T^{1}T^{2}T^{3}[/tex] at P
I may be misunderstanding what you are saying, but from how I read this statement that is already the case with the inertial coordinate system approach, by definition. Let's make this a little concrete. Suppose the vector at A is a timelike vector of magnitude 5, then we can choose an orthonormal basis at A such that T=(5,0,0,0). If we then parallel transport the bases and T from A to B along L1 and L2 we are guaranteed that at each point along the path (including B) the coordinates of T=(5,0,0,0) in the respective bases. But because the bases themselves are different, having the same coordinates does not imply that the vectors are the same.
Anamitra said:
I have a four vector in spacetime ...
I am requesting George [and of course DaleSpam]to comment on this issue .
I am glad to address this as the next topic, but I want to finish one topic before moving to the next.
Are we done with the chain of inertial frames? Do you now understand how the fact that the coordinates do not change along each path does not imply that the vectors are the same at the final point?
Let us assume that we cannot transport a vector from one point to another over a finite distance since it ends up with different directions as we proceed along different paths.This simply favors the concept underlined in "Curved spacetime and the Speed of Light" or in the thread: https://www.physicsforums.com/showpost.php?p=2846710&postcount=6
If we could calculate the relative velocity at a point by the parallel transport method we would have two local vectors and the speed of light could never be exceeded, considering the fact that parallel transport never changes the norm of a vector.An alternative evaluation of relative motion may favor my considerations.
Interstingly relative motion is a physical concept which we cannot override by mathematical failures.The incapability of the mathematical apparatus does not imply that the physical effect "Relative Motion" does not exist.If I am standing in curved spacetime and I observe a car in motion at a certain distance what do I conclude about its motion? If I cannot calculate/measure the distance from New York to Boston should it mean that the concept of distance is meaningless?
I would request the audience to consider the following thread with full consideration of the aforesaid ideas:
https://www.physicsforums.com/showpost.php?p=2862951&postcount=108
So again. Are we done with the inertial states? If yes, then which topic would you like to pursue next?
1) embedded spaces (vectors lifting out of tangent planes or not)
2) observation and math
I am glad to pursue either one next (I would recommend number 1), but this "shotgun" form of conversation where you repeatedly bring up multiple topics is counterproductive. Because experience has shown that it can take more than 100 posts to explain a single point, I will not work on a new point until we have finished the current one.
So again. Have we finished the inertial frames topic? Do you now understand how the fact that the coordinates do not change along each path does not imply that the vectors are the same at the final point? If yes, then which topic would you like next? Pick only one for now, and we will get to the rest later.
I am requesting DaleSpam to address the issues in thread #153
And I am requesting Anamitra to address the questions in post 152 first.
Are we done with the inertial frames? Do you now understand how the fact that the coordinates do not change along each path does not imply that the vectors are the same at the final point?
We simply cannot transport a vector from one point to another along different paths without changing its orientation[whether we choose inertial or non inertial paths]. This renders the calculation of relative velocity impossible by standard methods.
Now DaleSpam should have no difficulty in addressing thread #153,now that we have finished with the inertial states.
We can definitely pass to the issues of 1)Embedded spaces 2)Observation and Math at a later stage.
I think that your statements here are essentially correct. Parallel transport does not change the norm of a vector, so a timelike vector will never be parallel transported into a spacelike vector, meaning that you never get v>c. Parallel transport also results in a well-behaved coordinate-independent tensor. However it is not unique.
On the other hand, it is possible to simply define some number by some other formula and just call that number "relative velocity". While you can avoid the uniqueness issue that way you often introduce v>c problems, and you also will wind up with a coordinate-dependent number rather than a good tensor. This is the case with your example in a static spacetime, it is also the case with the redshift in the FLRW spacetime which is probably the most commonly used measure of relative velocity in any curved spacetime. Also, such measures don't usually generalize very well to other spacetimes.
This depends in large measure on your definition of "physical concept". I honestly have no strong opinion on the matter, so let me ask a few questions of you about your personal definition of "physical effect":
1) Do physical effects need to be measurable in principle?
2) Can a physical effect depend on the coordinate system used or should it be coordinate independent?
3) Are physical effects tied to any particular theories of physics?
4) Are concepts in other theories excluded?
5) Anything else that can help me understand your idea of a physical effect?
The modern view is that yes, if something cannot be measured then it is not physically meaningful. That is essentially the objection to Lorentz's Aether Theory and the reason that Einstein's SR was adopted instead.
After thinking about it for a while I realized that it might be helpful if I posted the way that I would answer these questions. As I mentioned before, I don't have any strong opinions on this so if you can clearly articulate a different definition then I will be glad to use it instead.
I would describe a physical effect or a physical concept as a measurable quantity in a specified theory of physics. So I wouldn't make statements like "X is a physical effect" but rather "X is a physical effect in theory Y".
1) They do need to be measurable (or calculated from measurements) in principle.
2) They can depend on the coordinate system.
3) They are tied to a theory of physics, just specify it.
4) Physical effects/concepts in one theory may not exist in another.
Extremely sorry for the delay. I was busy with some other work.But I am very much interested in the issues like embedding etc and most certainly I would like DaleSpam and others to continue in their participation in the thread.
Regarding the previous two threads of DaleSpam[#159 and #160]:They contain important material and I would try to give full consideration to them.
Regarding the concept of definition I have the following ideas:
1)A definition should be self consistent and also consistent with other concepts in physics.
2) It should help in understanding some reality or fact in physics.It should be connected with something that can be observed. This is again related to measurements being performed.
Parallel transport fails to define relative velocity.Does it mean that relative velocity cannot be measured or defined especially if some alternative procedure is adopted?Relative velocity is something very much "tangible" to us from the perspective of daily considerations. Should it become something "un-viewable" in curved spacetime?
If something is seen moving towards a black hole or a neutron star what could this observation mean if relative velocity is a meaningless concept?[We assume that the observation has been made from a space ship]
I believe that there many issues have to be considered.
I would try to reflect on these ideas in a serious manner. I will come back to them at a later stage in these threads.
Presently it would be interesting to hear from DaleSpam regarding embedding and other issues he has referred to.
An important issue to consider is: Is it essential to define relative velocity in curved space-time?
I would like to suggest this idea in view of what one may observe in the vicinity of curved spacetime for example particles/antiparticles flying outwards from a black hole[from beyond the Schwarzschild radius]For an observer at a distance the relative speed should be of greater concern than the local speed!
But I have already invited DaleSpam to talk on the issue of embedding. More important I would like to have some more time to reflect on the concept of relative speed in relation to curved spacetime .
You can define relative velocity if two objects are at the same point in space time (colliding with each other, or passing close-by). It's just an angle on the space-time diagram. You can also define relative velocity if you have a static space-time - which covers the black hole case, at least if it's not rotating. (It can probably be extended to cover a rotating black hole too, but I'd have to think about that case some more to nail down exactly how you'd do it.). This is just the velocity of the object relative to some static observer hovering above the black hole at constant coordinates. While you *can* define velocity this way, you'd be well advised to be careful to explain your definition - if you just talk about "the velocity relative to the black hole" without any more explanation, it won't really be clear what you meant.
I agree with this one.
I don't really like this one. The word "real" is notoriously difficult to define and such discussions always seem to degenerate.
Sure, so is simultaneity. That is a deficiency of relying on our daily experience.
There are some spacetimes (eg toroids) where it is generally not even clear if two objects are moving towards or away from each other.
Do you understand the difference between a manifold and a tangent space? Specifically, do you understand why a tangent space is a vector space and a manifold is not?
Regarding Simultaneity:Simultaneity is a well defined concept.The only point is that a pair of events which are simultaneous in a particular frame of reference may not be simultaneous in another.
Regarding manifolds and tangent spaces:One may think of establishing one to one correspondence between the points of a sphere and the [tex]{R^{2}}[/tex]. But this is not possible. But we may break up the surface of a sphere into small parts and establish one to one correspondence between the small surfaces and [tex]{R^{2}}[/tex].
The normal practice is to set up local charts at each point of the curved surface[the sphere in this case] . For each point on an infinitesimally small piece of surface[which we obtain by subdividing the original curved surface] we associate a point of [tex]{R^{2}}[/tex] by some mapping satisfying conditions of continuity,differentiability etc.Now at each point we have a tangent space [ [tex]{R^{2}[/tex]] and here we can define our vectors.
The entire union of the small curved surfaces[and against each such surface we have a tangent space] is the manifold. Incidentally the manifold and the tangent spaces are of the same dimension.
The idea may be extended to higher dimensions
Regarding the"real" and the "unreal":Common sense perceptions may lead us to believe something which is "not real " to be "real".This has happened in realm of physics on several occasions. But on each such occasion the matter was clearly tested out both from theoretical and experimental considerations.
The failure of a definition may not be a sufficient ground for dismissing a commonsense point of view.One has to be very careful !
Very often the commonsense point of view has undergone a modification instead of a complete dismissal. The rule of velocity addition has changed on the passage from the classical to the Special Relativity concepts--but the concept of velocity addition/subtraction is still there very much in conformity with what is observed.Does this concept of velocity addition/subtraction need to disappear totally in curved spacetime?
This is correct except for the very minor point that the charts need not be infinitesimal. In fact, you can easily map the entire sphere minus a single point onto [tex]{R^{2}}[/tex].
Because you can map the sphere (minus a point) onto [tex]{R^{2}}[/tex] and because [tex]{R^{2}}[/tex] is a vector space you might be tempted to think that the sphere is a vector space, but it doesn't have the vector operations which define a vector space. Ie, you don't add scalar multiples of two points to get a new point.
Yes. At each point we can take the derivatives of our coordinates to get the point's tangent space. This is a vector space since it does have a vector addition and scalar multiplication.
Are you comfortable with that?
Addition of Tensors/Vectors
Tensors admit themselves to a simple law of addition:if [tex]{a^{\alpha}}[/tex] and [tex]{b^{\alpha}}[/tex] are tensors then [tex]{a^{\alpha}}{+}{b^{\alpha}}[/tex] is a tensor.
If we treat [tex]{b^{\alpha}}[/tex] and [tex]{b^{\alpha}}[/tex] as velocity vectors their norms are always "c"[individually]
Referred to orthogonal coordinates,where [tex]{g_{\mu\nu}}{=}{0}[/tex] if [tex]{\mu}{\neq}{\nu}[/tex], we have:
[tex]{g_{\alpha\alpha}}{{(}{a^{\alpha}}{)}}^{2}}{=}{c^{2}}[/tex]
[tex]{g_{\alpha\alpha}}{{(}{b^{\alpha}}{)}}^{2}}{=}{c^{2}}[/tex]
Again:
[tex]{g_{\alpha\alpha}}{{{(}{a^{\alpha}{+}{b^{\alpha}}{)}^{2}}{=}{c^{2}}[/tex]
We have [tex]{4c^{2}}{=}{c^{2}}[/tex] if [tex]{a^{\alpha}}{=}{b^{\alpha}}[/tex] ----------------?
Can we treat the velocity four vector as a tensor of rank one, in view of the constancy of the norm and as such and apply the parallel transport equation to it?
You are correct. The set of all velocity four-vectors is not a vector space, for the same reason that the set of all unit vectors is not a vector space. A four-velocity is a unit tangent vector, and is a member of the tangent space which is a vector space, but it includes un-normalized vectors which are not four-velocities.
Velocity as a Four Vector:
Let us consider the flat spacetime
Four velocity: [tex]{(}{c \frac{dt}{{d}{\tau}}}{,}{\frac{dx_{1}}{dt} \frac{dt} {{d}{\tau}}}{,}{\frac{dx_{2}}{dt} \frac{ dt}{{d}{\tau}}}{,}{\frac{dx_{3}}{dt} \frac{dt}{{d}{\tau}}}{)}[/tex]
Or,
Four Velocity: [tex]{(}{c \frac{1}{\sqrt{1-{v^{2}/{c^{2}}}}}{,}{\frac{dx_{1}}{dt} \frac{1}{\sqrt{1-{v^{2}/{c^{2}}}}}{,}{\frac{dx_{2}}{dt}\frac{1}{\sqrt{1-{v^{2}/{c^{2}}}}}{,}{\frac{dx_{3}}{dt} \frac{1}{\sqrt{1-{v^{2}/{c^{2}}}}}{)}[/tex]
We consider the following case:
[tex]dx_{1}/{dt}{=}{0.9c}[/tex]
[tex]dx_{2}/{dt}{=}{0}[/tex]
[tex]dx_{1}/{dt}{=}{0}[/tex]
=>v=0.9c
[tex]{\gamma}{=}{2.29415}[/tex]
Four velocity=(2.29415c,2.06474c,0,0)
[[tex]{2.29415^{2}}{-}{2.06474^{2}}{=}{1}[/tex] ----------------approximately,because of decimal approximations]
But the spatial part of the four velocity[speed referred to proper time is exceeding the value of "c"].
I am requesting Dalespam[and of course others] to comment on the issue.
Considering the four velocity of light we have four infinitely large components but the norm is finite.How do you interpret this?The whole thing appears to be indeterminate.Of course the spatial part of the four velocity[celerity] is remotely connected to the concept of three velocity[quite distinct from it to be accurate] as we understand in the physical world.This becomes more conspicuous in the high speed regions.
Anamitra said:
Is it meaningful to talk of relative velocity between two moving points at a distance in curved space-time?
My own impression is that you revoke almost all meaning once you invoke curved spacetime.
Anamitra said:
Relative speed ,it appears from your condiderans,is a troublesome concept.The concept of parallel transport adds a serious attribute of non-uniqueness to the whole idea.
Good point.
Anamitra said:
Even then if I am standing at some point in curved space-time and an object flies past some other point(we consider somthing which is not a light ray), I should have some observation of relative motion physically.And I hope that from the physical point of view this observation should be of a unique natue!Is there any procedure in General Relativity that allows me to make such predictions ? In case there is some procedure/method can we apply it to a light ray?
In General Relativity, there is no way to tell, via direct observation, how much of the velocity that you perceive is due to actual motion through space, and how much is due to the motion of space.
So, no.
The Standard Model in General Relativity assumes first that the matter-density of the universe is uniform in space and time, then wherever our perceptions disagree with our assumptions, one simply applies a coordinate transformation, or "metric." The science of GR is to find the metric that will fulfill this function precisely.
George Jones said:
I'm not sure I follow you, so let's consider a simple example. Consider two static observers in Schwarzschild spacetime who both have the [itex]\theta[/itex] and [itex]\phi[/itex] values, but who hover at different values of [itex]r[/itex]. Using the method of parallel transport, what is their relative velocity? I think that this is fairly straightforward to compute, at least for geodesic radial paths.
The Schwartzchild metric is of another category of GR than the Standard Model. The fact that it predates Eddington is a strong point in its favor.
Anamitra said:
Regarding Simultaneity:Simultaneity is a well defined concept.The only point is that a pair of events which are simultaneous in a particular frame of reference may not be simultaneous in another.ns
Now, I agree with you, of course. But I think that advocates of the Standard Model believe that simultaneity is not so well defined. For example:
Chalnoth said:
I think you're somewhat misunderstanding simultaneity in relativity. The issue here is that if two events are separated by a space-like distance, then some hypothetical observer will see those two events as being simultaneous. This means that there is no "true" simultaneity at all: any simultaneity that we observe is purely imposed by the coordinate system we are using.
To properly deal with how this arbitrariness interacts with gravity, you really need to use General Relativity. Otherwise there's a chance you won't properly account for the differences in different coordinate systems, and may end up making a mistake without realizing it.
One example of such a coordinate system General Relativity might use is to use the "proper time" of many particles flying away from a single event. There is a surface of constant proper time which would appear hyperbolic in a minkowski space-time, but is mapped to a flat surface by a metric.
That is mostly correct, the four-velocity of light is undefined so it doesn't even have a norm. This should be clear by the fact that it involves division by zero. Remember that the four-velocity is the derivative of the worldline wrt proper time and that the derivative of proper time along a null worldline is, by definition, 0.
Ifthe proper speed of a particle [ and not a light ray/photon]exceeds the value of "c" continuously over a finite distance in curved space time, how would the situation be interpreted?I mean to say what is the physical significance of such an event?
Important to note:
1) I am not referring to the norm of the velocity four vector.
2) We are in curved spacetime now.
Anamitra said:
If the proper speed of a particle [ and not a light ray/photon]exceeds the value of "c" continuously over a finite distance in curved space time, how would the situation be interpreted?
What do you mean by proper speed? Could you define it?
We consider the metric:
[tex]{ds}^{2}{=}{g_{00}}{dt}^{2}{-}{g_{11}}{{dx}_{1}}^{2}{-}{g_{22}}{{dx}_{2}}^{2}{-}{g_{33}}{{dx}_{3}}^{2}[/tex]
We may define ds as the propertime interval[noting, c=1]on the infinitesimal scale.
Locally it is nothing different from what we find in Special Relativity.Interestingly ds is an invariant and it should not be different in any other frame.
[tex]{s}{=}{\int{ds}}[/tex]
[We are considering stationary fields]
Integration extends between the points concerned
Proper speed=[tex]{\frac{dL}{ds}}[/tex]
[tex]{dL}^{2}{=}{g_{11}}{{dx}_{1}}^{2}{+}{g_{22}}{{dx}_{2}}^{2}{+}{g_{33}}{{dx}_{3}}^{2}[/tex]
