Curvilinear coordinates question
In summary, the conversation discusses the derivation of polar coordinates using a transformation from Cartesian coordinates and knowledge of linear transformations and rotation matrices. The process involves finding a new frame of reference where the parameter theta becomes a coordinate, using the flow determined by the rotation group and its unit length orthogonal complement. The first step is considering the flow determined by the rotation group, where positive rotations map to circles centered at the origin. This allows for the derivation of the formulas for r and theta.
mnb96
715
Hi,
if we consider a transformation of coordinates Cartesian[itex]\rightarrow[/itex]Polar, it is straightforward to derive [itex]r = (x^2 + y^2)^{1/2}[/itex] and [itex]\theta = atan2(y/x)[/itex], because we actually know what our new coordinate system should be like.
Now let's pretend we have never seen polar coordinates, and we have no idea how to convert from cartesian to polar.
However, all we know is that we have the following family of linear transformations in [itex]\mathcal{R}^2[/itex],
[tex](\begin{array}{ccc} cos\theta & -sin\theta \\ sin\theta & cos\theta \end{array})[/tex]
which are actually rotation matrices acting on 2D vectors, and we would like to find a new frame of reference in which the parameter [itex]\theta[/itex] becomes one coordinate.
Is it possible from this knowledge only, to arrive at the formulas above for [itex]r,\theta[/itex]?
the flow on the plane that the action of the rotation group determines (for positive angles) and its unit length orthogonal complement (outward pointing) integrate to polar coordinates.
Hi!
thanks for the answer. I actually had the same idea you wrote but only as a visual intuition. Could you elaborate more at least the formalization of the process (not necessarily all the steps).
It is not very clear to me the first step: considering the flow determined by the rotation group.
Starting at any point in the plane positive rotations map generates a circle centered at the origin in the plane. this circles ia a parameterized curve and its derivatives are vectors of length 1 tangent to the circle. Once you have these vectors you can find their outward pointing orthogonal complements. This gives you the flow you want.
1. What are curvilinear coordinates?
Curvilinear coordinates are a set of coordinates used to describe the position of a point in a three-dimensional space. Unlike Cartesian coordinates, which use straight lines to measure distance, curvilinear coordinates use curved lines to measure distance.
2. What are the different types of curvilinear coordinates?
There are several types of curvilinear coordinates, including cylindrical, spherical, and ellipsoidal coordinates. Each type is used to describe a specific type of curved surface or object.
3. How are curvilinear coordinates used in science?
Curvilinear coordinates are commonly used in physics and engineering to describe the motion of objects in three-dimensional space. They are also used in fields such as fluid mechanics, electromagnetism, and astrophysics to solve complex problems involving curved surfaces and objects.
4. What are the advantages of using curvilinear coordinates?
One advantage of using curvilinear coordinates is that they can simplify complex mathematical equations and make them easier to solve. They also allow for the description of curved surfaces and objects, which cannot be accurately described using Cartesian coordinates.
5. What are some real-life applications of curvilinear coordinates?
Curvilinear coordinates have many real-life applications, such as in navigation systems, where they are used to calculate the position of an object on a curved surface, such as the Earth. They are also used in computer graphics to create 3D models of objects with curved surfaces, such as cars or buildings.
  • Differential Geometry
  • Differential Equations
