Cutting a Chalkboard - Is It Feasible?
  • Thread starter Thread starter IHateMayonnaise
    Cutting
The discussion centers on the feasibility of cutting a 4'x14' blackboard into two 4'x7' sections. Participants clarify that blackboards can be made from various materials, including ceramic, slate, wood, and glass. Cutting methods vary based on the material: a tile saw for ceramic, a glass cutter for glass, and a saw for wood. The consensus is that it is possible to cut the board, but the specific material will dictate the appropriate tools and techniques.
  • Understanding of blackboard materials (ceramic, slate, wood, glass)
  • Familiarity with cutting tools (tile saw, glass cutter, saw)
  • Knowledge of safety precautions when cutting materials
  • Basic DIY skills for handling large objects
  • Research the properties and cutting techniques for ceramic blackboards
  • Learn about using a tile saw and its maintenance
  • Explore the differences between slate and ceramic blackboards
  • Investigate safe handling practices for large, heavy materials
DIY enthusiasts, home improvement professionals, and anyone considering modifications to large blackboards or similar materials.
IHateMayonnaise
Hello friends,
I am in the process of acquiring a 4'x14' blackboard for free. The problem: it's a 4'x14' blackboard. I want a one for my apartment, however something of this magnitude would challenge the dimensions of my living quarters (not to mention I would have to rent a uhaul to move it). My question: how feasible would it be to cut the board in two to make two 4'x7' blackboards?
I imagine that cutting ceramic would be an arduous task to say the least, seeing as how it is the same material used as brake pads for many supercars. Also I am not sure what the ceramic is mounted on (stainless?) and how that will affect the cutting. All I want to know is whether or not this is worth my trouble, basically. I will clearly seek the advice of professions in the near future, but I thought Id throw it out here first :)
Smooches,
IHateMayonnaise
Are you sure it is ceramic? Chalkboards I have dealt with were surprisingly, glass.
That's a good question..
it looked like what I think a ceramic board looks like. Then again, I am no expert. Seems to be made of the same material as what they used at all the schools I went to
Aren't blackboards a bit like slate, surely you could just score and cut it like a tile (only an a larger scale.
Or it might just be wood, painted in blackboard paint.
In any event, it's not made of anything you can't cut. If it's wood, use a saw. If it's glass, use a glass cutter. If it's ceramic, use a tile saw or tile cutter.
killer that's the answer i was looking for. thanks yall
My new kitchen counter-top is slate from recycled blackboards recovered from an old school. You can rent a saw to cut slate. I borrowed one from a nice flooring guy in town. It looks like a miniature skill saw with a diamond blade and a long piece of Tygon tubing with a garden hose fitting and a valve to supply cooling water to the blade. If the board you have is not slate, but a ceramic material with a matte glaze, that water-cooled saw would cut that as well.
Blackboards are rarely made of slate anymore. New single-purpose boards are usually wood clad with steel sheet, and coated with a rough paint. Dual-sided boards with a whiteboard are sometimes made of coated glass.
Steel coated wood...that sounds like the most undesirable material to cut. Hopefully you don't have to resort to a hack saw!
Scribe both sides and give it a swift kick. This won't work worth a crap if its laminar construction, but, will make you feel better.
  • · Replies 22 ·
  • · Replies 22 ·
  • · Replies 51 ·
9K
