Cylinder rolling with a block inside it
The discussion focuses on maintaining the position of a small block inside a rotating cylinder. It emphasizes the need to analyze the forces acting on the block, particularly the constant magnitude but changing direction of the rotational force compared to the downward force of gravity. The worst-case scenario occurs when these forces oppose each other, necessitating a sufficient rotational speed to keep the block in place. The conversation also touches on the implications of using a rotating frame of reference, acknowledging that while gravity's direction changes, it can sometimes aid in keeping the block stable. Ultimately, understanding these dynamics is crucial for ensuring the block remains stationary relative to the cylinder during rotation.
IamVector
A cylinder with radius R spins around its axis with an
angular speed ω. On its inner surface there lies a small block;
the coefficient of friction between the block and the inner sur-
face of the cylinder is μ. Find the values of ω for which the
block does not slip (stays still with respect to the cylinder).
Consider the cases where (a) the axis of the cylinder is hori-
zontal; (b) the axis is inclined by angle α with respect to the
horizon.
so I as it is in rotation
it will experience centripetal force
and required angle for a object not to slip = tanμ
so I expressed cos and sin in it and got this relation
mω²rμ +mg(μ/√μ²+1) =mg(μ/√μ²+1)
but this is irrelevant for finding ω .
We need the small block to remain where it is respect to the rotating cylinder.
Taking the ground as reference: the magnitude of the force associate to rotation remains constant, but its direction constantly changes, while the force associate to gravity always points downwards.
We need to find out the worst condition (both forces oppose each other), making the cylinder spin fast enough as to keep rotation force being at least slightly greater than gravity force for that worst condition.
That applies to each degree of tilting of the cylinder ( (a) the axis of the cylinder is hori-
zontal; (b) the axis is inclined by angle α with respect to the horizon).
can I take rotating frame of reference??
Likes Lnewqban
but doing so will change the direction of gravity respect to cylinder i think.
Of course you can.
But remember, we only need to study the worst situations for both cases (analogy: top inverted position of a car in a roller coster).
Lnewqban said:
Of course you can.
But remember, we only need to study the worst situations for both cases.
wont the direction of gravity be changing constantly?
Likes Lnewqban
Yes, but sometimes it will help the small block to stay put, sometimes it will not.
  • · Replies 21 ·
  • · Replies 16 ·
